# Clip interpolated points with stl
**URL:** https://discourse.paraview.org/t/clip-interpolated-points-with-stl/4669
**Created:** [June 24, 2020, 12:50pm UTC](https://discourse.paraview.org/t/clip-interpolated-points-with-stl/4669 "2020-06-24T12:50:04Z")
### Author: ![Kenichiro-Yoshimi](https://discourse.paraview.org/letter_avatar_proxy/v4/letter/k/ecc23a/32.png) [@Kenichiro-Yoshimi](https://discourse.paraview.org/u/Kenichiro-Yoshimi)
#### Post date: [June 25, 2020, 6:57am UTC](https://discourse.paraview.org/t/clip-interpolated-points-with-stl/4669/2 "2020-06-25T06:57:01Z")
Hello,
I hope the following link is helpful to compute the signed distance field from STL to points in the Programmable filter.
> [@Compute the signed distance field from a polygonal mesh](https://discourse.paraview.org/t/compute-the-signed-distance-field-from-a-polygonal-mesh/123):
> Goal Compute the signed distance field from points in a data set to a polygonal mesh. The signed distance field has many applications in computational geometry, and can be used, for instance, to find intersections of objects with a polygonal mesh. Background A signed distance field is a point-associated field that gives the distance from each point in a data set to some location or object. In this case, we’ll compute the signed distance as the nearest point on a polygonal mesh. The sign of the …
_[View the full topic](https://discourse.paraview.org/t/clip-interpolated-points-with-stl/4669)._
