Empty arrays in resample with dataset filter
Hello, I have two vtk files, 1 with structured cell data from OpenFOAM and one is unstructured nodes. The domain bounds are the same but the x and y axis are switched. I used transform filter so that the domains overlap. then I applied resample with data set filter to map the structured mesh data on the unstructured nodes but the arrays came out empty. The video of the problem and the structured and unstructured nodes vtk files are attached (VTKFiles - Google Drive)
Looks ok to me, btw you do not need a delaunay:
state.pvsm (901.2 KB)
Hello, Thank you for your reply. I need to map the structured mesh data on the points. I guess you did the opposite. Is the procedure same?
I did just that, you can open the provided state file.
yes, I saw the state file and understood. I was not applying the last filter convert to point cloud. Thank you so much for the help.
