# help/about causes segmentation fault
**URL:** <https://discourse.paraview.org/t/help-about-causes-segmentation-fault/14025>\
**Category:** ParaView Support\
**Created:** [February 26, 2024, 2:32pm UTC](https://discourse.paraview.org/t/help-about-causes-segmentation-fault/14025 "2024-02-26T14:32:14Z")\
**Posts on this page:** 1\
**Showing post:** 13
**Author:** ![mwestphal](https://discourse.paraview.org/user_avatar/discourse.paraview.org/mwestphal/32/17_2.png) [@mwestphal](https://discourse.paraview.org/u/mwestphal)\
**Post date:** [February 28, 2024, 12:27pm UTC](https://discourse.paraview.org/t/help-about-causes-segmentation-fault/14025/13 "2024-02-28T12:27:14Z")
> [@I'm using Ubuntu 22 and ParaView osmesa binary crashes on rendering](https://discourse.paraview.org/t/im-using-ubuntu-22-and-paraview-osmesa-binary-crashes-on-rendering/14046):
> This is a known issue that affect all binary versions of ParaView from [https://paraview.org/download:](https://paraview.org/download:)[https://gitlab.kitware.com/paraview/paraview/-/issues/22350](https://gitlab.kitware.com/paraview/paraview/-/issues/22350) How can I check if I am affected by this issue ? Run this: /lib/x86\_64-linux-gnu/libc.so.6 If it says something \>= 2.35, you are affected and cannot use the osmesa binary release. What can I do to work around this bug ? Use the EGL release from [https://paraview.org/download](https://paraview.org/download) Compile ParaView with OSMesa yourself using the paravie…
_[View the full topic](https://discourse.paraview.org/t/help-about-causes-segmentation-fault/14025)._
