# Plot over line gives NaN
**URL:** https://discourse.paraview.org/t/plot-over-line-gives-nan/2207
**Created:** [July 12, 2019, 3:19pm UTC](https://discourse.paraview.org/t/plot-over-line-gives-nan/2207 "2019-07-12T15:19:46Z")
**Showing post:** 16
### Author: ![Kenneth\_Moreland](https://discourse.paraview.org/user_avatar/discourse.paraview.org/kenneth_moreland/32/15033_2.png) [@Kenneth\_Moreland](https://discourse.paraview.org/u/Kenneth_Moreland)
#### Post date: [July 17, 2019, 2:12pm UTC](https://discourse.paraview.org/t/plot-over-line-gives-nan/2207/16 "2019-07-17T14:12:09Z")
The problem is that you are trying to plot right on the edge of your mesh, and numerical inaccuracies are causing points of the line to be outside of your mesh. (This is not a criticism of your data. Rather, this is just the nature of floating point numbers on a computer.)
 ![Capture](https://discourse.paraview.org/uploads/default/original/2X/b/be8a01f64d569506de4f90eddf12ee55592c2078.png)
Take a look at this captured screenshot. Here I have zoomed in the mesh at one of the places where the `Plot Over Line` is giving a NaN value. (It is the topmost point in the mesh and the rightmost point in the plot.) Then I have selected 3 mesh points around that location and I’m showing the numeric information for those 3 points in the superimposed `Find Data` dialog.
You can see that although the points with ids 387 and 713 have an x coordinate value of 0. However, the point with id 8 (which happens to be in the middle) has x coordinate value of -1.71663e-16. This is just slightly to the left of the line you are plotting on. The difference is imperceptible and I’m sure below any realistic significant digits. However, it means that when `Plot Over Line` intersects the line around those mesh cells, it computes it as just outside the boundary of the mesh, and thus assigns NaN values (which is the correct behavior).
The solution is simple. Move the line to the left by an epsilon amount so that it is always inside the mesh. I changed the x coordinate of both `Point 1` and `Point 2` to be `-1e-15`, and that seemed to work just fine as shown in this second screen capture.
 ![Capture-fixed](https://discourse.paraview.org/uploads/default/original/2X/0/0f1b323703fa0679e3f883679d55b8d8aed63dc4.png)
_[View the full topic](https://discourse.paraview.org/t/plot-over-line-gives-nan/2207)._
