# Point labels available with PV 5.7?
**URL:** https://discourse.paraview.org/t/point-labels-available-with-pv-5-7/2478
**Created:** [August 27, 2019, 8:22am UTC](https://discourse.paraview.org/t/point-labels-available-with-pv-5-7/2478 "2019-08-27T08:22:03Z")
**Showing post:** 7
### Author: ![jourdain](https://discourse.paraview.org/user_avatar/discourse.paraview.org/jourdain/32/11_2.png) [@jourdain](https://discourse.paraview.org/u/jourdain)
#### Post date: [March 24, 2020, 4:01pm UTC](https://discourse.paraview.org/t/point-labels-available-with-pv-5-7/2478/7 "2020-03-24T16:01:27Z")
Hi @cobo,
I’ve done it the following way inside a ParaViewWeb app:
[Line Dataset] \> ExtractTopHoleFilter \> DataLabelRepresentation
I’ve created a new Representation via an XML file (no code) that I load as a plugin in PV 5.8
I’ve created a filter ExtractTopHoleFilter using the python plugin infrastructure.
That way, by loading a Python and an XML file as plugins, I was able to do exactly what you are trying to achieve.
For reference here is the XML part, for the filter, I’m sure you can figure it out.
```xml
<ServerManagerConfiguration>
  <ProxyGroup name="representations">
    <Extension name="GeometryRepresentation">
      <RepresentationType
        subproxy="DataLabelRepresentation"
        text="Labels"
      <SubProxy>
        <Proxy
            name="DataLabelRepresentation"
            proxygroup="representations"
            proxyname="DataLabelRepresentation"
        <ShareProperties subproxy="SurfaceRepresentation">
          <Exception name="Input" />
          <Exception name="Visibility" />
        </ShareProperties>
        <ExposedProperties>
            <Property name="PointFieldDataArrayName" />
            <Property name="PointLabelBold" />
            <Property name="PointLabelColor" />
            <Property name="PointLabelFontFamily" />
            <Property name="PointLabelFontSize" />
            <Property name="PointLabelFormat" />
            <Property name="PointLabelItalic" />
            <Property name="PointLabelJustification" />
            <Property name="PointLabelOpacity" />
            <Property name="PointLabelShadow" />
            <Property name="PointLabelVisibility" />
            <Property name="MaximumNumberOfLabels" />
        </ExposedProperties>
      </SubProxy>
    </Extension>
  </ProxyGroup>
</ServerManagerConfiguration>
HTH,
Seb
_[View the full topic](https://discourse.paraview.org/t/point-labels-available-with-pv-5-7/2478)._
