# Slow Programmable Filter
**URL:** https://discourse.paraview.org/t/slow-programmable-filter/3848
**Category:** ParaView Support
**Created:** [March 19, 2020, 7:24pm UTC](https://discourse.paraview.org/t/slow-programmable-filter/3848 "2020-03-19T19:24:13Z")
**Posts on this page:** 16
**Page:** 1
<div class="post-metadata">
### Author: ![woodscn](https://discourse.paraview.org/user_avatar/discourse.paraview.org/woodscn/32/3226_2.png) [@woodscn](https://discourse.paraview.org/u/woodscn)
#### Post date: [March 19, 2020, 7:24pm UTC](https://discourse.paraview.org/t/slow-programmable-filter/3848/1 "2020-03-19T19:24:13Z")
</div>
I’ve created a programmable filter to do some analysis, but it’s running more slowly than I expected. Does anyone have ideas for how to improve the filter? It’s running over ~65k cells. I’d also love it to be parallel, but I’m not sure if that’s possible.
Thanks,
Nathan Woods
```auto
def flatten(input, output):
    output.ShallowCopy(input)
    numCells = output.GetNumberOfCells()
    cellData = input.GetCellData()
    r = cellData.GetArray('radius')
    v = cellData.GetArray('vol')
    d = cellData.GetArray('den')
    def base_bump(t, tau):
        x = (t-tau)**2
        if x > 1:
            out = 0
        else:
            out = exp(1/(x-1))/0.443993816237631
        return out
    def bump(r, rp, h):
        return base_bump(r/h, rp/h)**(1/h)
    h = 1
    dtype = r.GetDataType()
    out = r.NewInstance()
    out.SetName("denbar")
    print(numCells)
    for indi in range(0, numCells):
        temp = 0
        for indj in range(0, numCells):
            temp += d.GetValue(indj)*v.GetValue(indj)*bump(
                r.GetValue(indi),r.GetValue(indj),h)
        out.InsertValue(indi,temp)
# output.AddArray(out)
input = self.GetInputDataObject(0, 0)
output = self.GetOutputDataObject(0)
if input.IsA("vtkMultiBlockDataSet"):
    output.CopyStructure(input)
    iter = input.NewIterator()
    iter.UnRegister(None)
    iter.InitTraversal()
    while not iter.IsDoneWithTraversal():
        curInput = iter.GetCurrentDataObject()
        curOutput = curInput.NewInstance()
        curOutput.UnRegister(None)
        output.SetDataSet(iter, curOutput)
        flatten(curInput, curOutput)
        iter.GoToNextItem();
else:
### Author: ![utkarsh.ayachit](https://discourse.paraview.org/user_avatar/discourse.paraview.org/utkarsh.ayachit/32/39_2.png) [@utkarsh.ayachit](https://discourse.paraview.org/u/utkarsh.ayachit)
#### Post date: [March 19, 2020, 7:30pm UTC](https://discourse.paraview.org/t/slow-programmable-filter/3848/2 "2020-03-19T19:30:36Z")
</div>
I’d not recommend using the `GetValue`/`SetValue` APIs. Instead you want to use the numpy wrapped API for modifying data arrays.
Refer to examples in ParaView Guide, Chapter 12.
The VTK/ParaView numpy API is also described in this series of blog posts starting [here](https://blog.kitware.com/improved-vtk-numpy-integration).
#### Post date: [March 19, 2020, 7:33pm UTC](https://discourse.paraview.org/t/slow-programmable-filter/3848/3 "2020-03-19T19:33:59Z")
</div>
I tried the NumPy version for quite a while, but I eventually gave up. It certainly didn’t seem any faster; should I expect it to be?
#### Post date: [March 19, 2020, 7:37pm UTC](https://discourse.paraview.org/t/slow-programmable-filter/3848/4 "2020-03-19T19:37:26Z")
</div>
it’d be faster if you can rephrase your code to now use for loops over each element in Python instead using `numpy` functions and expressions. Essentially, avoid `for .. in range(0, numCells)`, you never want to do that if you care about performance.
#### Post date: [March 19, 2020, 8:04pm UTC](https://discourse.paraview.org/t/slow-programmable-filter/3848/5 "2020-03-19T20:04:57Z")
</div>
I have a vectorized version ready to time. I’m putting it here in case PView hangs. Comments welcome.
r = inputs[0]['radius']
v = inputs[0]['vol']
d = inputs[0]['den']
    x = (t-tau)**2
    if x > 1:
        out = 0
    else:
    return out
def bump(r, rp, h):
vbump = frompyfunc(bump,2,1)
h = vbump(r,r,1)
out = (v*d)@h
output.CellData.append(out, "denbar")
else:
#### Post date: [March 19, 2020, 9:42pm UTC](https://discourse.paraview.org/t/slow-programmable-filter/3848/6 "2020-03-19T21:42:22Z")
</div>
Another NumPy attempt. This one is far slower than the VTK version, probably due to the looping construct to form the h array. The commented portion works instantaneously, but returns all zeros.
    x = (t-tau)**2
    if x > 1:
        out = 0
    else:
    return out
def bump(r, rp, h):
# This doesn't work for some reason
# vbump = frompyfunc(bump,3,1)
# h = vbump(r,r,1+0*r)
h = array([[bump(ri,rj,1) for ri in r] for rj in r])
out = inner(v*d,h)
#### Post date: [March 19, 2020, 10:45pm UTC](https://discourse.paraview.org/t/slow-programmable-filter/3848/7 "2020-03-19T22:45:19Z")
</div>
The GetValue version I posted above seems to be returning a single value per block, rather than a value per cell. Does anyone have any idea why that might be?
 ![BrokenFilter](https://discourse.paraview.org/uploads/default/original/2X/e/e51bd05a05d6961baf320819d22f351362ea68c0.png)
def integrate(input, output):
        x = (t-tau)**2
        if x > 1:
            out = 0
        else:
        return out
    def bump(r, rp, h):
    h = 1
        temp = 0
    output.GetCellData().AddArray(out)
        integrate(curInput, curOutput)
else:
#### Post date: [March 19, 2020, 11:10pm UTC](https://discourse.paraview.org/t/slow-programmable-filter/3848/8 "2020-03-19T23:10:26Z")
</div>
This, unfortunately, suffers from the same “looping in python” problem, except now you’re using the generator to do the loop for you e.g. `[.. for rj in r]`.
As an example, let’s say we want to raise all items in an array “radius” to power 2. Two ways to do this:
```auto
r = inputs[0].PointData["radius"]
# 1. slower way script:
r2 = array([x**2 for x in r])
# 2. faster way
r2 = numpy.power(r, 2)
You will have to express your logic in `bump`/`bump_base` and expressions over numpy arrays. And use numpy functions, where ever possible. HTH.
#### Post date: [March 19, 2020, 11:19pm UTC](https://discourse.paraview.org/t/slow-programmable-filter/3848/9 "2020-03-19T23:19:59Z")
</div>
I’m working in parallel on both approaches. A purely vectorized approach looks like this:
from vtk.numpy_interface.algorithms import shape
r = inputs[0].CellData['radius']
v = inputs[0].CellData['vol']
d = inputs[0].CellData['den']
def bump(r, rp, h):
    import numpy as np
    x = np.subtract.outer(r/h,rp/h)**2
    return where(x<1, np.exp(1/(x-1))/0.443993816237631,0*x)**(1/h)
h = bump(r,r,1)
out = inner(h,v*d)
print(max(h))
Unfortunately, this fails with the following error message:
`AttributeError: 'VTKCompositeDataArray' object has no attribute 'exp'`
Presumably, this is because np.exp doesn’t know how to treat VTK objects, but I’m not sure what else to try.
#### Post date: [March 20, 2020, 2:02am UTC](https://discourse.paraview.org/t/slow-programmable-filter/3848/10 "2020-03-20T02:02:59Z")
</div>
use `exp` from the `vtk.numpy_interface.algorithms` module instead
#### Post date: [March 20, 2020, 2:42am UTC](https://discourse.paraview.org/t/slow-programmable-filter/3848/11 "2020-03-20T02:42:37Z")
</div>
Unfortunately, using the function from algs yields the same error:
Full code:
import numpy as np
import vtk.numpy_interface.algorithms as algs
def bump(r, rp, h):
    return where(x<1, algs.exp(1/(x-1))/0.443993816237631, 0*x)**(1/h)
h = bump(r,r,1)
out = inner(h,v*d)
print(max(h))
#### Post date: [March 20, 2020, 12:08pm UTC](https://discourse.paraview.org/t/slow-programmable-filter/3848/12 "2020-03-20T12:08:47Z")
</div>
Do you have sample dataset to share, so I can try I your script out locally and see what’s going on? Thanks.
#### Post date: [March 20, 2020, 4:47pm UTC](https://discourse.paraview.org/t/slow-programmable-filter/3848/13 "2020-03-20T16:47:36Z")
</div>
I put together an example using Wavelet.
Is the `where` function not implemented fully? I got errors testing on the Wavelet source that it only accepted 1 positional argument.
I’m also having trouble accessing the `outer` methods of functions. Those should be present for numpy ufuncs, and they cause the function to compute on all pairs of values from the input arrays, rather than element-wise. Various work-arounds are slow.
[ForKitware.pvsm](https://discourse.paraview.org/uploads/short-url/ciLeADhvWRYktgTp2xdSY6Tb2KD.pvsm) (606.6 KB)
#### Post date: [March 30, 2020, 4:05pm UTC](https://discourse.paraview.org/t/slow-programmable-filter/3848/14 "2020-03-30T16:05:14Z")
</div>
Any luck with this? Once I fixed the bug in my VTK implementation, the whole thing became too slow to use reliably.
#### Post date: [March 31, 2020, 8:57am UTC](https://discourse.paraview.org/t/slow-programmable-filter/3848/15 "2020-03-31T08:57:17Z")
</div>
Your script had a small typo, change `d = inputs[0].CellData['RTdata']` to `d = inputs[0].CellData['RTData']` (note the case for RTData). With that, it produces a result for the state file you attached.
#### Post date: [October 31, 2020, 3:52pm UTC](https://discourse.paraview.org/t/slow-programmable-filter/3848/16 "2020-10-31T15:52:52Z")
</div>
I wanted to put a note here on the final result. It turns out that I am essentially unable to use the NumPy interface for this problem, because I run into memory problems for large data.
The problem statement is this one:
```auto
r is an array of size (ncells), which makes x an array of size (ncells\*\*2) For a million cells, that’s a trillion-element array (~7TB?), and my workstation couldn’t even construct it, failing with error:
```auto
  File "<string>", line 22, in <module>
  File "<string>", line 6, in RequestData
MemoryError
I believe that the conclusion I should draw from this is that I need to derive a new algorithm and/or use the older VTK interface.
For completeness, the precise script I was using was this:
```auto
import numpy
m = inputs[0].CellData['mass']
h = 1
x = numpy.subtract.outer(r/h,r/h)**2
#bump = where(x<1, exp((x-1)**-1)*2.252283620690761, 0)**1/h
#out = inner(bump, mass)
#output.PointData.append(out, "out")
