# Transform: How to rotate stl about a given axis?
**URL:** https://discourse.paraview.org/t/transform-how-to-rotate-stl-about-a-given-axis/7765
**Category:** ParaView Support
**Created:** [August 5, 2021, 4:22am UTC](https://discourse.paraview.org/t/transform-how-to-rotate-stl-about-a-given-axis/7765 "2021-08-05T04:22:56Z")
**Posts on this page:** 4
**Page:** 1
<div class="post-metadata">
### Author: ![Rezaul\_Tharim](https://discourse.paraview.org/user_avatar/discourse.paraview.org/rezaul_tharim/32/7300_2.png) [@Rezaul\_Tharim](https://discourse.paraview.org/u/Rezaul_Tharim)
#### Post date: [August 5, 2021, 4:22am UTC](https://discourse.paraview.org/t/transform-how-to-rotate-stl-about-a-given-axis/7765/1 "2021-08-05T04:22:56Z")
</div>
I have a vtk showing a particle model of a screw being twisted. I tried to insert an stl file for a screwdriver in the correct position and tried rotating it at the same rate as my vtk file. I added a Filter-\>Transform-\>Rotation(2) about z-axis, and added the final angle on the animation panel. I assumed the rotation would occur about the center of the stl itself but the stl started spinning about an unknown axis instead.
1. How do I figure out which axis the stl is moving about?
2. How do I make it rotate about a specific axis?
### Author: ![mwestphal](https://discourse.paraview.org/user_avatar/discourse.paraview.org/mwestphal/32/17_2.png) [@mwestphal](https://discourse.paraview.org/u/mwestphal)
#### Post date: [August 5, 2021, 8:34am UTC](https://discourse.paraview.org/t/transform-how-to-rotate-stl-about-a-given-axis/7765/2 "2021-08-05T08:34:22Z")
</div>
> [@Rezaul\_Tharim](#):
It is rotating around the origin.
You want to use RotateAroundPoint mode in Transfrom filter. Available in the nightlies.
#### Post date: [August 25, 2021, 9:14am UTC](https://discourse.paraview.org/t/transform-how-to-rotate-stl-about-a-given-axis/7765/4 "2021-08-25T09:14:31Z")
</div>
![image](https://discourse.paraview.org/uploads/default/original/2X/9/985181df171152b528bfca856bbea613fd3c1fd0.png)
I tried to change the origin in the transform filter but it doesn’t seem to be working.
Could you perhaps send a screenshot to indicate how to use the RotateAroundPoint mode?
#### Post date: [August 25, 2021, 9:34am UTC](https://discourse.paraview.org/t/transform-how-to-rotate-stl-about-a-given-axis/7765/5 "2021-08-25T09:34:52Z")
</div>
Sorry, not in 5.9.1 but present in the nightly, you can download it here:
[https://www.paraview.org/download/](https://www.paraview.org/download/)
Filter → Transform
In the combo box, instead of transform choose RotateAroundOriginTransform
 ![a](https://discourse.paraview.org/uploads/default/original/2X/6/62329108056a2f59e0fb522c77b39335c38e941d.png)
