# Visualization of data using Paraview
**URL:** https://discourse.paraview.org/t/visualization-of-data-using-paraview/4703
**Created:** [June 28, 2020, 1:30pm UTC](https://discourse.paraview.org/t/visualization-of-data-using-paraview/4703 "2020-06-28T13:30:11Z")
**Showing post:** 14
### Author: ![cory.quammen](https://discourse.paraview.org/user_avatar/discourse.paraview.org/cory.quammen/32/11193_2.png) [@cory.quammen](https://discourse.paraview.org/u/cory.quammen)
#### Post date: [July 10, 2020, 1:08pm UTC](https://discourse.paraview.org/t/visualization-of-data-using-paraview/4703/14 "2020-07-10T13:08:33Z")
Try the **SPH Dataset Interpolator**. This will interpolate the point data onto the surface according to an interpolation kernel you can set. To use it, select your point source, then add the **SPH Dataset Interpolator**. In the dialog that pops up, leave the Input to the selected point source, then click on the **Source** input port on the left. On the right, choose the STL. Click OK and apply. Play with the **Spatial Step** to adjust how the point data is “splatted” onto the STL (bigger values make a bigger splat). HTH.
_[View the full topic](https://discourse.paraview.org/t/visualization-of-data-using-paraview/4703)._
