# Visualization of data using Paraview
**URL:** https://discourse.paraview.org/t/visualization-of-data-using-paraview/4703
**Created:** [June 28, 2020, 1:30pm UTC](https://discourse.paraview.org/t/visualization-of-data-using-paraview/4703 "2020-06-28T13:30:11Z")
**Showing post:** 8
### Author: ![Deepa](https://discourse.paraview.org/user_avatar/discourse.paraview.org/deepa/32/2213_2.png) [@Deepa](https://discourse.paraview.org/u/Deepa)
#### Post date: [July 8, 2020, 7:12am UTC](https://discourse.paraview.org/t/visualization-of-data-using-paraview/4703/8 "2020-07-08T07:12:25Z")
Thanks a lot for the clarification.
I still have a few more questions. I’d like to use Point Volume Interpolator described in the documentation available [here](https://blog.kitware.com/point-and-smoothed-particle-hydrodynamics-sph-interpolation-in-paraview/).
> [@Kenneth\_Moreland](#):
> If you are using `Resample With Dataset` , then you do not need to have the same number of points (but you will need point coordinates).
Yes, I don’t have the field values at all points. The values are generated from simulations only at discrete points (x,y,z coordinates defined in the snapshot below)
 ![Untitled](https://discourse.paraview.org/uploads/default/original/2X/a/acd2fea09235682cbd6e7d5aba86c0aab4c6741a.png)
The table on the top is the input data and the table below it has been generated using `Table to points`. But I oculdn’t clearly understand how `Table to points` works and how to use `Resample with Dataset` filter. When I try to seelct `Resample with Dataset` from Add filters tab, `Resample with Dataset` isn’t available for access.
[input](https://github.com/DeepaMahm/misc/blob/master/demo.vtp)
[data](https://github.com/DeepaMahm/misc/blob/master/data.txt)
Could you please offer instructions on how to proceed from here?
cross-posted [here](https://stackoverflow.com/questions/62797530/perform-point-volume-interpolation-in-paraview)
_[View the full topic](https://discourse.paraview.org/t/visualization-of-data-using-paraview/4703)._
