Different colors using OSPRay pathtracer with PV 5.9
Dear ParaView-Team,
I noticed that ParaView 5.9.0 renders images with different colors compared to ParaView 5.8.0 when using the OSPRay pathtracer. Please see the attached screenshots.
I used the following PV binaries from your website and ran it on Ubuntu 20.04:
  • ParaView-5.9.0-MPI-Linux-Python3.8-64bit
  • ParaView-5.8.0-MPI-Linux-Python3.7-64bit
I used the following steps to obtain the screenshots:
  • started PV with paraview output/soma-clustering/soma-clusterin.pvsm (data files attached)
  • clicked on Enable Ray Tracing
  • changed the back end to OSPRay pathtracer
  • set the samples per pixel to 10.
Which settings should I use on 5.9.0 to obtain the same result as on 5.8.0?
Many thanks in advance for your help!
Lukas
data.zip (1.7 MB)
o̶s̶m̶e̶s̶a ospray changed form 1.X to 2.0, that may explains it.
@Dave_DeMarle
@mwestphal - I believe you meant OSPRay and autocorrect probably left it with osmesa.
Hi Lukas. It is more likely that the new backplate and environmental color options briefly mentioned in the 5.9 release notes are the culprit here. Try setting the path traced background to solid black and then switch the background mode to backplate. That way the object will only receive light energy from the lights themselves, not the “sky”,
Hi Dave,
Thanks for your reply! I applied your recommended settings, but the difference is barely noticeable.
Is there anything else which could cause this problem?
The colors in the pathtraced image do not correspond to the colors in the legend.
Hey Lukas, do you have the “light kit” toggled on in 5.9 but not 5.8? Just looking at the images it seems like the 5.9 scene is receiving light from somewhere that the 5.8 isn’t. That could be due to an either an env map providing light (Like Dave mentioned turning background mode to backplate turns this off), or there are new lights in the scene somewhere.
Finally, tons of stuff changed with OSPRay with the new 5.9 update. I wouldn’t be shocked if renders with the same settings were slightly different between versions. If nothing else works to darken your 5.9 scene just set the “light scale” toggle lower.
Hi Marston,
The light kit is enabled in both versions with identical settings.
I created the following python script so you can see the whole pipeline.
The script generates the same output as shown in the screenshots in my initial post for 5.8 and 5.9 using the binaries from your website.
from paraview.simple import *
# create a new 'XML Partitioned Unstructured Grid Reader'
somaClusteringCell = XMLPartitionedUnstructuredGridReader(registrationName='SomaClusteringCell-*', FileName=['output/soma-clustering/SomaClusteringCell-6000.pvtu'])
somaClusteringCell.PointArrayStatus = ['cell_type_', 'diameter_']
# get animation scene
animationScene1 = GetAnimationScene()
# update animation scene based on data timesteps
animationScene1.UpdateAnimationUsingDataTimeSteps()
# get active view
# reset view to fit data
renderView1.ResetCamera()
# get the material library
materialLibrary1 = GetMaterialLibrary()
# update the view to ensure updated data information
renderView1.Update()
# create a new 'Glyph'
glyph1 = Glyph(registrationName='Glyph1', Input=somaClusteringCell,
    GlyphType='Sphere')
glyph1.OrientationArray = ['POINTS', 'No orientation array']
glyph1.ScaleArray = ['POINTS', 'diameter_']
glyph1.ScaleFactor = 1.0
glyph1.GlyphTransform = 'Transform2'
glyph1.GlyphMode = 'All Points'
# show data in view
glyph1Display = Show(glyph1, renderView1, 'GeometryRepresentation')
# init the 'PiecewiseFunction' selected for 'ScaleTransferFunction'
glyph1Display.ScaleTransferFunction.Points = [-0.9965844750404358, 0.0, 0.5, 0.0, 0.9965844750404358, 1.0, 0.5, 0.0]
# init the 'PiecewiseFunction' selected for 'OpacityTransferFunction'
glyph1Display.OpacityTransferFunction.Points = [-0.9965844750404358, 0.0, 0.5, 0.0, 0.9965844750404358, 1.0, 0.5, 0.0]
# set scalar coloring
ColorBy(glyph1Display, ('POINTS', 'cell_type_'))
# rescale color and/or opacity maps used to include current data range
glyph1Display.RescaleTransferFunctionToDataRange(True, False)
# show color bar/color legend
glyph1Display.SetScalarBarVisibility(renderView1, True)
# get color transfer function/color map for 'cell_type_'
cell_type_LUT = GetColorTransferFunction('cell_type_')
# get opacity transfer function/opacity map for 'cell_type_'
cell_type_PWF = GetOpacityTransferFunction('cell_type_')
# set camera
renderView1.CameraPosition = [-147.90239225387725, 987.3370677382073, 1256.9188143692575]
renderView1.CameraFocalPoint = [253.3733764288308, 198.8307305001966, 209.17141330374292]
renderView1.CameraParallelScale = 354.92567318384994
# Enable OSPRay
renderView1.BackEnd = 'OSPRay pathtracer'
pm = paraview.servermanager.vtkSMProxyManager
if pm.GetVersionMajor() == 5 and pm.GetVersionMinor() == 9:
    renderView1.EnvironmentalBG = [0.0, 0.0, 0.0]
    renderView1.Backgroundmode = 'Backplate'
renderView1.SamplesPerPixel = 10
renderView1.EnableRayTracing = 1
Thanks,
Lukas
Forgot to mention that I tried to reduce the light-scale setting, but it didn’t give the desired result.
probably related:
See: https://gitlab.kitware.com/vtk/vtk/-/merge_requests/8577
Any news on this?
Do you have an update regarding this issue?
