What language is that? I suggest using Paraview 5.10 to return a meaningful error message.
I suspect what you’re seeing here is an error message in Chinese which has been garbled into ASCII.
Chinese Simplified
with Paraview5.10.0,the error message is:
E:\pythonProject>python test.py
( 24.516s) [paraview ] vtkSocket.cxx:459 ERR| vtkClientSocket (0000020FDCA60650): Socket error in call to connect. 鐢变簬杩炴帴鏂瑰湪涓€娈垫椂闂村悗娌℃湁姝g‘绛斿鎴栬繛鎺ョ殑涓绘満娌℃湁鍙嶅簲锛岃繛鎺ュ皾璇曞け璐ャ €?
( 24.571s) [paraview ] vtkClientSocket.cxx:51 ERR| vtkClientSocket (0000020FDCA60650): Failed to connect to server 192.168.20.60:11111
( 24.577s) [paraview ]vtkTCPNetworkAccessMana:395 WARN| vtkTCPNetworkAccessManager (0000020FC8D20C90): Connect failed. Retrying for 38.911 more seconds.
( 46.641s) [paraview ] vtkSocket.cxx:459 ERR| vtkClientSocket (0000020FDCA60650): Socket error in call to connect. 鐢变簬杩炴帴鏂瑰湪涓€娈垫椂闂村悗娌℃湁姝g‘绛斿鎴栬繛鎺ョ殑涓绘満娌℃湁鍙嶅簲锛岃繛鎺ュ皾璇曞け璐ャ €?
( 46.647s) [paraview ] vtkClientSocket.cxx:51 ERR| vtkClientSocket (0000020FDCA60650): Failed to connect to server 192.168.20.60:11111
( 46.649s) [paraview ]vtkTCPNetworkAccessMana:395 WARN| vtkTCPNetworkAccessManager (0000020FC8D20C90): Connect failed. Retrying for 16.839 more seconds.
( 68.709s) [paraview ] vtkSocket.cxx:459 ERR| vtkClientSocket (0000020FDCA60650): Socket error in call to connect. 鐢变簬杩炴帴鏂瑰湪涓€娈垫椂闂村悗娌℃湁姝g‘绛斿鎴栬繛鎺ョ殑涓绘満娌℃湁鍙嶅簲锛岃繛鎺ュ皾璇曞け璐ャ €?
( 68.715s) [paraview ] vtkClientSocket.cxx:51 ERR| vtkClientSocket (0000020FDCA60650): Failed to connect to server 192.168.20.60:11111
( 68.718s) [paraview ]vtkTCPNetworkAccessMana:391 ERR| vtkTCPNetworkAccessManager (0000020FC8D20C90): Connect timeout.
File "E:\pythonProject\test.py", line 3, in <module>
cone = Cone()
File "C:\Program Files\ParaView 5.10.0-Windows-Python3.9-msvc2017-AMD64\bin\Lib\site-packages\paraview\simple.py", line 2650, in CreateObject
px = paraview._backwardscompatibilityhelper.GetProxy(module, key, no_update=True)
File "C:\Program Files\ParaView 5.10.0-Windows-Python3.9-msvc2017-AMD64\bin\Lib\site-packages\paraview\_backwardscompatibilityhelper.py", line 881, in GetProxy
return builtins.getattr(module, key)(**kwargs)
File "C:\Program Files\ParaView 5.10.0-Windows-Python3.9-msvc2017-AMD64\bin\Lib\site-packages\paraview\servermanager.py", line 281, in __init__
self.Initialize(None, update)
File "C:\Program Files\ParaView 5.10.0-Windows-Python3.9-msvc2017-AMD64\bin\Lib\site-packages\paraview\servermanager.py", line 2590, in aInitialize
raise RuntimeError ('Cannot create a proxy without a session.')
RuntimeError: Cannot create a proxy without a session.
test.py code:
from paraview.simple import *
Connect("192.168.20.60")
cone = Cone()
#shrinkFilter = Shrink(cone)
#Show(cone)
#Render()
collaboration_manager = servermanager.ActiveConnection.Session.GetCollaborationManager()
print("{0}".format(collaboration_manager.GetUserId()))
collaboration_manager.PromoteToMaster(collaboration_manager.GetUserId())
That looks a whole lot better but I can’t read Chinese. Does it help you resolve the connection problem?
collaboration_manager.UpdateUserInformations()
Cone()
collaboration_manager.PromoteToMaster(1)
after running the test1.py,the paraview GUI 5.10.0does not respond
This Chinese is similar to garbled code. It can’t help me solve the connection problem
Are both machines now running Paraview 5.10.0?
yes,both computers running Paraview 5.10.0
There’s clearly a problem with the error message which most likely contains value placeholders in a formatted string. I have just pushed a fix for that to VTK but it won’t help you right now.
I think this is a Windows permission problem. Since your computers are connected in a local network have you disabled the firewalls between the client and server machines?
I’m sure it’s not a computer permission problem, because my project involves three types of files, T3D, S3D and D3D. Among them, T3D files will not get stuck, and the other two files will get stuck
The Paraview nightly build should now generate a meaningful error message in Chinese. Please try it.
