Is it possible to add labels to contour lines?
@wascott I was able to do this successfully with Paraview 5.6.0-975-g3fceb06(5.6 from download wesite), but it fails for the version Paraview 5.6.0-1074-gdcb1bac (nightly binaries given by @cory.quammen under this post) Running Paraview on SSH -X
As soon as I select contour filter after the slice,
Error: Cannot create decorator of type “NonPolyDataInputDecorator”
Screen shot:
Hy will you please help me how to give “%” sign there ? and in my case its showing the value all the counter line? how can i set only one time value for a contour line ?
To display the % character, in the Edit Label Properties in the Find Data tool, the Point Label Format may be described as follows
%3.0f %%
If you want to label one on the contour line, you may want to manually select one point with the selection tool.
Thanks a lot
