joeh
(Joseph G. Hennessey)
21
Ben,
If I set
-DENABLE_mpi=ON \
-DUSE_SYSTEM_mpi=ON \
-DSUPERBUILD_PROJECT_PARALLELISM=20 \
and then use
make -j 20 -l 20 install
Then I am making a parallel build with an external mpi version, that is also built in parallel, correct?
I have
-DENABLE_netcdf=ON \
but I have not explicitly set HDF5
but it is being built as it is a prerequisite for netcdf
– Enabling hdf5 for: netcdf
Thanks,
Joe
There were some issues with compiling with MPI compilers and a serial CGNS / HDF5. Those have been fixed in the latest seacas master branch.
ben.boeckel
(Ben Boeckel (Kitware))
23
I don’t care at all about how many -j cores the build process uses. I care whether you’re using MPI. This says you are (-DENABLE_mpi=ON).
Thanks, I’ll look at pulling those patches in (since we prefer to sit on tags).
ben.boeckel
24
Here is what I found: https://gitlab.kitware.com/vtk/vtk/-/merge_requests/8565
Hrm. That’s a lot of changes. Something went wonky with another ioss update…tracking it down.
joeh
25
Ben,
I have found that the issue is still present in ParaView 5.10.0-RC2
Thanks,
Joe
ben.boeckel
27
I believe that 5.11 should have this fixed. I seem to remember fixing MPI_Comm “no MPI” stuff since.
