please share FA000000.vtu
Thank you very much for the advice.
I didn’t understand one thing though, what did you use Calculator for?
It is a bit of a trick but the GenerateId replace the current “Scalar” field, which is a bug and should be fixed. Calculator works around this bug.
So I simply open calculator, click apply and work around the bug? Then use Generate Ids starting from Calculator1?
No, I shared a .pvsm you can try it.
In any case, I use the calculator to duplicate f into Result
