1D exodus file crashing on apple silicon
I am using a 16 inch M1 Max MacBook Pro and I am using ParaView 5.10.0 to visualize some simulation results that are stored in an exodus file format. When attempting to load in the results of a 1D simulation ParaView immediately crashes. However, loading 2D simulation results works fine.
I have also tried to use ParaView 5.9.1 via rosetta. But the ParaView application will not even open on my computer. When I try to open it, it simply stalls and my computer says that the application is not responding.
Any help on getting the 1D files to load would be greatly appreciated!
please share your data.
SakiyamaBC.e (670.6 KB)
Yet another IOSS issue. Please open an issue on our gitlab:
https://gitlab.kitware.com/paraview/paraview/-/issues
and use pv 5.9.1 for the time being
Thread 1 "paraview" received signal SIGABRT, Aborted.
0x00007ffff7e0fd22 in raise () from /usr/lib/libc.so.6
(gdb) bt
#0  0x00007ffff7e0fd22 in raise () from /usr/lib/libc.so.6
#1  0x00007ffff7df9862 in abort () from /usr/lib/libc.so.6
#2  0x00007ffff7df9747 in __assert_fail_base.cold () from /usr/lib/libc.so.6
#3  0x00007ffff7e08616 in __assert_fail () from /usr/lib/libc.so.6
#4  0x00007fffdb6a91fd in vtkioss_Ioex::DatabaseIO::get_sidesets (this=0x55555aff5520) at /home/glow/work/paraview/pv1/src/VTK/ThirdParty/ioss/vtkioss/exodus/Ioex_DatabaseIO.C:1682
#5  0x00007fffdb6a043b in vtkioss_Ioex::DatabaseIO::read_meta_data__ (this=0x55555aff5520) at /home/glow/work/paraview/pv1/src/VTK/ThirdParty/ioss/vtkioss/exodus/Ioex_DatabaseIO.C:507
#6  0x00007fffdb5ac77b in vtkioss_Ioss::DatabaseIO::read_meta_data (this=0x55555aff5520) at /home/glow/work/paraview/pv1/src/VTK/ThirdParty/ioss/vtkioss/Ioss_DatabaseIO.h:320
#7  0x00007fffdb58f2ca in vtkioss_Ioss::Region::Region (this=0x5555575ac640, iodatabase=0x55555aff5520, my_name="") at /home/glow/work/paraview/pv1/src/VTK/ThirdParty/ioss/vtkioss/Ioss_Region.C:315
#8  0x00007fffe8e5be99 in __gnu_cxx::new_allocator<vtkioss_Ioss::Region>::construct<vtkioss_Ioss::Region, vtkioss_Ioss::DatabaseIO*> (this=0x7fffffffc16f, __p=0x5555575ac640) at /usr/include/c++/11.1.0/ext/new_allocator.h:156
#9  0x00007fffe8e5a832 in std::allocator_traits<std::allocator<vtkioss_Ioss::Region> >::construct<vtkioss_Ioss::Region, vtkioss_Ioss::DatabaseIO*> (__a=..., __p=0x5555575ac640) at /usr/include/c++/11.1.0/bits/alloc_traits.h:512
#10 0x00007fffe8e5911c in std::_Sp_counted_ptr_inplace<vtkioss_Ioss::Region, std::allocator<vtkioss_Ioss::Region>, (__gnu_cxx::_Lock_policy)2>::_Sp_counted_ptr_inplace<vtkioss_Ioss::DatabaseIO*> (this=0x5555575ac630, __a=...)
    at /usr/include/c++/11.1.0/bits/shared_ptr_base.h:519
#11 0x00007fffe8e5679c in std::__shared_count<(__gnu_cxx::_Lock_policy)2>::__shared_count<vtkioss_Ioss::Region, std::allocator<vtkioss_Ioss::Region>, vtkioss_Ioss::DatabaseIO*> (this=0x7fffffffc318, __p=@0x7fffffffc310: 0x0,
    __a=...) at /usr/include/c++/11.1.0/bits/shared_ptr_base.h:650
#12 0x00007fffe8e53352 in std::__shared_ptr<vtkioss_Ioss::Region, (__gnu_cxx::_Lock_policy)2>::__shared_ptr<std::allocator<vtkioss_Ioss::Region>, vtkioss_Ioss::DatabaseIO*> (this=0x7fffffffc310, __tag=...)
    at /usr/include/c++/11.1.0/bits/shared_ptr_base.h:1337
#13 0x00007fffe8e4d041 in std::shared_ptr<vtkioss_Ioss::Region>::shared_ptr<std::allocator<vtkioss_Ioss::Region>, vtkioss_Ioss::DatabaseIO*> (this=0x7fffffffc310, __tag=...) at /usr/include/c++/11.1.0/bits/shared_ptr.h:409
#14 0x00007fffe8e42639 in std::allocate_shared<vtkioss_Ioss::Region, std::allocator<vtkioss_Ioss::Region>, vtkioss_Ioss::DatabaseIO*> (__a=...) at /usr/include/c++/11.1.0/bits/shared_ptr.h:861
#15 0x00007fffe8e38e1b in std::make_shared<vtkioss_Ioss::Region, vtkioss_Ioss::DatabaseIO*> () at /usr/include/c++/11.1.0/bits/shared_ptr.h:877
#16 0x00007fffe8e1ca1e in vtkIOSSReader::vtkInternals::GetRegion (this=0x55555b018a30, dbasename="/home/glow/tmp/SakiyamaBC.e", fileid=0) at /home/glow/work/paraview/pv1/src/VTK/IO/IOSS/vtkIOSSReader.cxx:1423
#17 0x00007fffe8e19a15 in vtkIOSSReader::vtkInternals::UpdateTimeInformation (this=0x55555b018a30, self=0x55555afceae0) at /home/glow/work/paraview/pv1/src/VTK/IO/IOSS/vtkIOSSReader.cxx:951
#18 0x00007fffe8e26ebb in vtkIOSSReader::ReadMetaData (this=0x55555afceae0, metadata=0x55555afcd6c0) at /home/glow/work/paraview/pv1/src/VTK/IO/IOSS/vtkIOSSReader.cxx:2979
FYI @utkarsh.ayachit
When I try to open ParaView 5.9.1 on my computer the application does not open. I get a message that says application not responding. My computer already has Rosetta downloaded and other applications run on it without issue.
Different issue I have no idea of. @cory.quammen
Opens fine on ParaView 6.0.0-RC2 on an M4 mac.
