I am new in using Paraview. I want to contour 2D array data in CSV format (the attached result_test.csv (2.5 KB) ). The array is 10x10 size and each node of the array has its value. The contour will be based on these values. I have seen that there is a solution about the CSV with x,y coordinates, but in my CSV file, I just have the array and values. Could anyone can help me, please?
Yeah, because the values in my data are at the grid nodes without x,y,z coordinates. I can transfer it with x,y coordinates but it is time cost as I have so many files like that, so I am trying to contour without modifying the format How about .vtk format? If there is no possible, I will change the format as yours manually.
Hi Thank you so much. I have written a sed command to transform the output and got what I need by using the filters Table to Points and Delaunay2D . Do you think using vtk is better than csv so that I don’t need to use filters each time.
