2D velocity field analysis
I am attempting to analyze a time series of .csv files. Each file corresponds to a time point. Within each file is X position, Y position, Velocity in X direction (u), Velocity in Y direction (v). The entire series of .csv files can be accessed here: Box
I have not used ParaView before but I have found so many helpful posts. However, detail was lacking so I decided to document my pipeline and ask how I can achieve my goal, which is to be able to select a region of the flow field and produce a Velocity (relative to flow direction) vs. Time plot. Here is what one flow field at one time point looks like:
My pipeline is as follows:
The raw .csv table looks like this (371 rows). After opening a .csv file, I learned I need to change my field delimiter to a semicolon. I am not sure about the other check boxes:
First, I convert the .csv data into point data using Table To Points filter. There is no Z dimension (2D points), so “Velocity v[m/s]” is just a place holder in this case. I selected “Keep All Data Arrays” because I need all 4 columns and I couldn’t select those I needed later on if I did not check this:
Now the new table looks like this:
What is “Points_Magnitude” and how is it useful?
I know that I need to convert my 2 scalars (Velocity u and Velocity v) into a vector, which will result in 3 columns: X position, Y position, and the velocity vector. I use “Calculator” to multiply the scalars by iHat and jHat respectively (did I do this correctly?). I called the new values “Velocity calculate (mm/s)”:
Here is the resulting table:
And when I use the Plot Selection Over Time filter and select part of my vector field I get this plot:
My problem is, I need to quantify velocity in the flow direction (bottom right to top left), so that I can plot negative velocity. I know I can plot over a line (but haven’t gotten that to work).
How do I 1) quantify negative velocity (relative to flow direction), 2) a specified region, and 3) over time?
Thank you for following along!
This is in response to the first question.
  1. quantify negative velocity
The following steps are possible:
  1. Create a direction vector field dir of length 1 using Python Calculator:
    Expression: np.array([-1/sqrt(2), -1/sqrt(2), 0])
    Array Name: dir
  2. Project the velocity vector Velocity onto the direction vector dir using the Python Calculator:
    Expression: dot(Velocity, dir)*dir
    Array Name: projected
The result of projecting the velocity vectors is shown in the figure below. These vectors may be quantified by statistical processing.
This is the length (or norm) of the vector between the origin and the point. If I understand correctly, this is not relevant in your case.
