I use those commands, however, before that I extract the block and get “CellDatatoPoint”.
Then I used to get the slice and then contour.
However, I suspect, I should not use slicing.
Now, I have realized that the issue is the boundary, which I need to make it transparent to visualize what is inside. As in the attached image in previous message, the rectangular box is transparent.
I even tried not to include the wall boundary, but in this case it does not show the flow dynamics since I deactivate the wall.
Is there any way of making the boundary transparent?
I understand.
Since I use ParaView over HPCC it takes some time to show the results.
My internet connection deactivated the access.
I will try the way you suggested.
