Chm
(Chris)
November 8, 2022, 10:02am
1
Dear Team,
I am extracting the surface (select points on) from an 3D object and getting the below output Points:
|171.055|-134.464|-1132.1|
|181.162|-136.666|-1132.1|
|171.055|-135.655|-1132.1|
Is this normal ? How can i get normal x,y,z coordinates ?
Thanks a lot
mwestphal
(Mathieu Westphal (Kitware))
November 8, 2022, 10:08am
2
What is wrong with these values ?
Chm
(Chris)
November 9, 2022, 6:22am
3
i thought it was too large values, but its ok and im running a few examples for testing
Thanks for you reply
Chm
(Chris)
November 9, 2022, 7:07pm
4
Hello again,
I have two identιcal 3D objects. How can i set them to have the same x,y,z
system ? Please check the attachment showing the 3D objects.
Thanks in advance.
mwestphal
November 10, 2022, 7:46am
5
Transform filter maybe ?
But if they are identical, except for their coordinates, why do you need to do that ?
Chm
(Chris)
November 10, 2022, 3:57pm
6
Thanks a lot for your prompt reply.
I checked this filter but i see that this is for manually registration, is there any filter for automatic registration ?
cory.quammen
(Cory Quammen (Kitware))
November 10, 2022, 8:02pm
7
ParaView does not have object registration methods. You may want to check 3DSlicer , which does have registration methods available.
Chm
(Chris)
November 10, 2022, 8:29pm
8
Can i use Iterative Closest Point Transform Filter for registration or its not working as plugin ?
cory.quammen
November 10, 2022, 9:14pm
9
It is not exposed in ParaView.
Chm
(Chris)
November 13, 2022, 9:59pm
10
thanks lot Cory, i am trying to find a solution.
