I am trying to generate a high resolution image using the OSPRAY path tracer. The background is using an image.
When I try to save a screenshot larger than my layout resolution, the object itself is well rendered but the background is tiled (although the background image has the same resolution as the screenshot I want to create)
I’m afraid the way background are managed in OSPRay (and in ParaView in general) do not account for the high resolution screenshot of ParaView.
You have two ways to work around this.
Use a bigger resolution on your screen: As long as the resolution you ask for as equal or smaller than the resolution of the render window, this bug will not appear, by increasing your screen resolution you increase your view resolution.
Manual compositing: Cut your screenshot in four part, make four high res screenshot, cut each part of each screenshot and composite it together. I know, lots of manual work, but this is ok for a single screenshot I suppose.
