Hi all,
On a Ryzen AI Max (Strix Halo) laptop the ParaView GUI hangs as soon as anything translucent has to be rendered with depth peeling enabled.
This happens every time I apply Clip or Slice, because the plane widget is translucent. As soon as I apply the filter the GUI freezes without any error message and has to be killed. The same thing happens without any filter if I just set Opacity = 0.5 on the Wavelet. Loading and rendering opaque datasets works fine, with hardware acceleration.
Note: in pvpython (same machine, same GPU, on-screen window) the same pipeline, including a vtkImplicitPlaneWidget2, renders fine. The hang only happens in the Qt GUI.
Disabling depth peeling is a working workaround. Any ideas on how to solve it?
Thanks!
System
- ParaView 6.2.0 (Windows binary installer)
- CPU/GPU: AMD Ryzen AI Max 390 with Radeon 8050S (integrated, Strix Halo)
- Windows 11 Home, build 26300
- AMD driver 32.0.23033.5002 (June 2026). OpenGL: “4.6.0 Compatibility Profile Context 25.30.33.05.260603”, vendor “ATI Technologies Inc.”
