I have set up two machines as a remote server,and their memory has 8G.The total memory of the server as I understand it should now be 16G.But when I use a client on another machine to connect to the server, I found that the server only has 8G.
And when I open a dataset on paraview client,I found that only the first core is obviously used, the rest of the cores are not very used.So,I implore you to answer my doubt.
Which reader are you using ? What is your file format ?
How do you run the pvserver ?
Thank you for your reply! I opened a .ply file directly using paraview. And I made a ParaView server by two virtual machines on a single host machine. I use openmpi to run the pvserver as follow image.
The vtkPLYReader is not parallel aware. You should either use another format that will distribute the data or distribute the data yourself usnig the DistributeData filter in ParaView.
Thank you for telling me this.I also want to know why the memory on the server side is not 16GiB.Please forgive me for not understanding this.
When I use the paraview client to connect to the server, the client has this warning. What is causing this?
Unrelated to your initial question.
This error can either means that :
- There is no rendering capabilities server-side (eg: no built with osmesa or no Xorg server running)
- The server is not configured to use the rendering capabilities (eg: by using DISPLAY=:0)
That is ok by the way, as long as your geometries are not too big.
I want to visualize a larger geometry in parallel.I found that the Xorg server on server-side is running and the DISPLAY has set to :0,so how can I solve this error?
does this work : DISPLAY=:0 glxinfo and what is the output ?
https://idownvotedbecau.se/imageofcode
Paste the full output please.
I’m sorry I didn’t paste the full output before.
name of display: :0
display: :0 screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.4
server glx extensions:
GLX_ARB_create_context, GLX_ARB_create_context_no_error,
GLX_ARB_create_context_profile, GLX_ARB_fbconfig_float,
GLX_ARB_framebuffer_sRGB, GLX_ARB_multisample,
GLX_EXT_create_context_es2_profile, GLX_EXT_create_context_es_profile,
GLX_EXT_fbconfig_packed_float, GLX_EXT_framebuffer_sRGB,
GLX_EXT_import_context, GLX_EXT_libglvnd, GLX_EXT_no_config_context,
GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info, GLX_EXT_visual_rating,
GLX_MESA_copy_sub_buffer, GLX_OML_swap_method, GLX_SGIS_multisample,
GLX_SGIX_fbconfig, GLX_SGIX_pbuffer, GLX_SGIX_visual_select_group,
GLX_SGI_make_current_read
client glx vendor string: Mesa Project and SGI
client glx version string: 1.4
client glx extensions:
GLX_ARB_context_flush_control, GLX_ARB_create_context,
GLX_ARB_create_context_no_error, GLX_ARB_create_context_profile,
GLX_ARB_create_context_robustness, GLX_ARB_fbconfig_float,
GLX_ARB_framebuffer_sRGB, GLX_ARB_get_proc_address, GLX_ARB_multisample,
GLX_EXT_buffer_age, GLX_EXT_create_context_es2_profile,
GLX_EXT_create_context_es_profile, GLX_EXT_fbconfig_packed_float,
GLX_EXT_framebuffer_sRGB, GLX_EXT_import_context,
GLX_INTEL_swap_event, GLX_MESA_copy_sub_buffer,
GLX_MESA_multithread_makecurrent, GLX_MESA_query_renderer,
GLX_MESA_swap_control, GLX_OML_swap_method, GLX_OML_sync_control,
GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
GLX_SGIX_visual_select_group, GLX_SGI_make_current_read,
GLX_SGI_swap_control, GLX_SGI_video_sync
GLX version: 1.4
GLX extensions:
GLX_MESA_copy_sub_buffer, GLX_MESA_query_renderer, GLX_MESA_swap_control,
GLX_OML_swap_method, GLX_OML_sync_control, GLX_SGIS_multisample,
GLX_SGI_make_current_read, GLX_SGI_video_sync
Extended renderer info (GLX_MESA_query_renderer):
Vendor: VMware, Inc. (0x15ad)
Device: SVGA3D; build: RELEASE; LLVM; (0x405)
Version: 19.2.8
Accelerated: no
Video memory: 1MB
Unified memory: no
Preferred profile: core (0x1)
Max core profile version: 3.3
Max compat profile version: 3.3
Max GLES1 profile version: 1.1
Max GLES[23] profile version: 2.0
OpenGL vendor string: VMware, Inc.
OpenGL renderer string: SVGA3D; build: RELEASE; LLVM;
OpenGL core profile version string: 3.3 (Core Profile) Mesa 19.2.8
OpenGL core profile shading language version string: 3.30
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
GL_AMD_conservative_depth, GL_AMD_draw_buffers_blend,
GL_AMD_shader_trinary_minmax, GL_AMD_texture_texture4,
GL_ANGLE_texture_compression_dxt3, GL_ANGLE_texture_compression_dxt5,
GL_ARB_ES2_compatibility, GL_ARB_ES3_compatibility,
GL_ARB_arrays_of_arrays, GL_ARB_blend_func_extended,
GL_ARB_clear_buffer_object, GL_ARB_clear_texture,
GL_ARB_compressed_texture_pixel_storage, GL_ARB_conservative_depth,
GL_ARB_copy_buffer, GL_ARB_copy_image, GL_ARB_debug_output,
GL_ARB_depth_buffer_float, GL_ARB_depth_clamp, GL_ARB_direct_state_access,
GL_ARB_draw_buffers, GL_ARB_draw_buffers_blend,
GL_ARB_draw_elements_base_vertex, GL_ARB_draw_instanced,
GL_ARB_explicit_attrib_location, GL_ARB_explicit_uniform_location,
GL_ARB_fragment_coord_conventions, GL_ARB_fragment_shader,
GL_ARB_framebuffer_object, GL_ARB_framebuffer_sRGB,
GL_ARB_get_program_binary, GL_ARB_get_texture_sub_image,
GL_ARB_half_float_pixel, GL_ARB_half_float_vertex,
GL_ARB_instanced_arrays, GL_ARB_internalformat_query,
GL_ARB_internalformat_query2, GL_ARB_invalidate_subdata,
GL_ARB_map_buffer_alignment, GL_ARB_map_buffer_range, GL_ARB_multi_bind,
GL_ARB_occlusion_query2, GL_ARB_parallel_shader_compile,
GL_ARB_pixel_buffer_object, GL_ARB_point_sprite,
GL_ARB_program_interface_query, GL_ARB_provoking_vertex,
GL_ARB_robustness, GL_ARB_sample_shading, GL_ARB_sampler_objects,
GL_ARB_seamless_cube_map, GL_ARB_separate_shader_objects,
GL_ARB_shader_bit_encoding, GL_ARB_shader_objects,
GL_ARB_shader_subroutine, GL_ARB_shader_texture_lod,
GL_ARB_shading_language_420pack, GL_ARB_shading_language_packing,
GL_ARB_sync, GL_ARB_texture_buffer_object,
GL_ARB_texture_compression_rgtc, GL_ARB_texture_cube_map_array,
GL_ARB_texture_filter_anisotropic, GL_ARB_texture_float,
GL_ARB_texture_gather, GL_ARB_texture_multisample,
GL_ARB_texture_non_power_of_two, GL_ARB_texture_query_levels,
GL_ARB_texture_query_lod, GL_ARB_texture_rectangle, GL_ARB_texture_rg,
GL_ARB_texture_rgb10_a2ui, GL_ARB_texture_storage,
GL_ARB_texture_storage_multisample, GL_ARB_texture_swizzle,
GL_ARB_timer_query, GL_ARB_uniform_buffer_object,
GL_ARB_vertex_array_bgra, GL_ARB_vertex_array_object,
GL_ARB_vertex_attrib_binding, GL_ARB_vertex_buffer_object,
GL_ARB_vertex_shader, GL_ARB_vertex_type_2_10_10_10_rev,
GL_ATI_blend_equation_separate, GL_ATI_texture_float, GL_EXT_abgr,
GL_EXT_blend_equation_separate, GL_EXT_draw_buffers2,
GL_EXT_draw_instanced, GL_EXT_framebuffer_blit,
GL_EXT_framebuffer_multisample, GL_EXT_framebuffer_multisample_blit_scaled,
GL_EXT_framebuffer_object, GL_EXT_framebuffer_sRGB,
GL_EXT_packed_depth_stencil, GL_EXT_packed_float,
GL_EXT_pixel_buffer_object, GL_EXT_provoking_vertex,
GL_EXT_shader_integer_mix, GL_EXT_texture_array,
GL_EXT_texture_compression_dxt1, GL_EXT_texture_compression_rgtc,
GL_EXT_texture_compression_s3tc, GL_EXT_texture_filter_anisotropic,
GL_EXT_texture_integer, GL_EXT_texture_sRGB, GL_EXT_texture_sRGB_decode,
GL_EXT_texture_shared_exponent, GL_EXT_texture_snorm,
GL_EXT_texture_swizzle, GL_EXT_timer_query, GL_EXT_transform_feedback,
GL_EXT_vertex_array_bgra, GL_IBM_multimode_draw_arrays,
GL_KHR_context_flush_control, GL_KHR_debug, GL_KHR_no_error,
GL_KHR_parallel_shader_compile, GL_KHR_texture_compression_astc_ldr,
GL_KHR_texture_compression_astc_sliced_3d, GL_MESA_pack_invert,
GL_MESA_shader_integer_functions, GL_MESA_texture_signed_rgba,
GL_NV_conditional_render, GL_NV_depth_clamp, GL_NV_packed_depth_stencil,
GL_OES_EGL_image, GL_S3_s3tc
OpenGL version string: 3.3 (Compatibility Profile) Mesa 19.2.8
OpenGL shading language version string: 3.30
OpenGL context flags: (none)
OpenGL profile mask: compatibility profile
OpenGL extensions:
GL_APPLE_packed_pixels, GL_ARB_ES2_compatibility,
GL_ARB_ES3_compatibility, GL_ARB_arrays_of_arrays,
GL_ARB_blend_func_extended, GL_ARB_clear_buffer_object,
GL_ARB_clear_texture, GL_ARB_color_buffer_float, GL_ARB_compatibility,
GL_ARB_depth_buffer_float, GL_ARB_depth_clamp, GL_ARB_depth_texture,
GL_ARB_direct_state_access, GL_ARB_draw_buffers,
GL_ARB_draw_buffers_blend, GL_ARB_draw_elements_base_vertex,
GL_ARB_draw_instanced, GL_ARB_explicit_attrib_location,
GL_ARB_explicit_uniform_location, GL_ARB_fragment_coord_conventions,
GL_ARB_fragment_program, GL_ARB_fragment_program_shadow,
GL_ARB_fragment_shader, GL_ARB_framebuffer_object,
GL_ARB_framebuffer_sRGB, GL_ARB_get_program_binary,
GL_ARB_get_texture_sub_image, GL_ARB_half_float_pixel,
GL_ARB_half_float_vertex, GL_ARB_instanced_arrays,
GL_ARB_internalformat_query, GL_ARB_internalformat_query2,
GL_ARB_invalidate_subdata, GL_ARB_map_buffer_alignment,
GL_ARB_map_buffer_range, GL_ARB_multi_bind, GL_ARB_multisample,
GL_ARB_multitexture, GL_ARB_occlusion_query, GL_ARB_occlusion_query2,
GL_ARB_parallel_shader_compile, GL_ARB_pixel_buffer_object,
GL_ARB_point_parameters, GL_ARB_point_sprite,
GL_ARB_shading_language_100, GL_ARB_shading_language_420pack,
GL_ARB_shading_language_packing, GL_ARB_shadow, GL_ARB_sync,
GL_ARB_texture_border_clamp, GL_ARB_texture_buffer_object,
GL_ARB_texture_compression, GL_ARB_texture_compression_rgtc,
GL_ARB_texture_cube_map, GL_ARB_texture_cube_map_array,
GL_ARB_texture_env_add, GL_ARB_texture_env_combine,
GL_ARB_texture_env_crossbar, GL_ARB_texture_env_dot3,
GL_ARB_texture_gather, GL_ARB_texture_mirrored_repeat,
GL_ARB_texture_multisample, GL_ARB_texture_non_power_of_two,
GL_ARB_texture_query_levels, GL_ARB_texture_query_lod,
GL_ARB_texture_rectangle, GL_ARB_texture_rg, GL_ARB_texture_rgb10_a2ui,
GL_ARB_texture_storage, GL_ARB_texture_storage_multisample,
GL_ARB_texture_swizzle, GL_ARB_timer_query, GL_ARB_transpose_matrix,
GL_ARB_uniform_buffer_object, GL_ARB_vertex_array_bgra,
GL_ARB_vertex_array_object, GL_ARB_vertex_attrib_binding,
GL_ARB_vertex_buffer_object, GL_ARB_vertex_program, GL_ARB_vertex_shader,
GL_ARB_vertex_type_2_10_10_10_rev, GL_ARB_window_pos,
GL_ATI_blend_equation_separate, GL_ATI_draw_buffers,
GL_ATI_fragment_shader, GL_ATI_separate_stencil,
GL_ATI_texture_env_combine3, GL_ATI_texture_float, GL_EXT_abgr,
GL_EXT_bgra, GL_EXT_blend_color, GL_EXT_blend_equation_separate,
GL_EXT_blend_func_separate, GL_EXT_blend_minmax, GL_EXT_blend_subtract,
GL_EXT_compiled_vertex_array, GL_EXT_copy_texture, GL_EXT_draw_buffers2,
GL_EXT_draw_instanced, GL_EXT_draw_range_elements, GL_EXT_fog_coord,
GL_EXT_framebuffer_blit, GL_EXT_framebuffer_multisample,
GL_EXT_framebuffer_multisample_blit_scaled, GL_EXT_framebuffer_object,
GL_EXT_framebuffer_sRGB, GL_EXT_gpu_program_parameters,
GL_EXT_gpu_shader4, GL_EXT_multi_draw_arrays, GL_EXT_packed_depth_stencil,
GL_EXT_packed_float, GL_EXT_packed_pixels, GL_EXT_pixel_buffer_object,
GL_EXT_point_parameters, GL_EXT_provoking_vertex, GL_EXT_rescale_normal,
GL_EXT_secondary_color, GL_EXT_separate_specular_color,
GL_EXT_shader_integer_mix, GL_EXT_shadow_funcs, GL_EXT_stencil_two_side,
GL_EXT_stencil_wrap, GL_EXT_subtexture, GL_EXT_texture, GL_EXT_texture3D,
GL_EXT_texture_array, GL_EXT_texture_buffer_object,
GL_EXT_texture_compression_s3tc, GL_EXT_texture_cube_map,
GL_EXT_texture_edge_clamp, GL_EXT_texture_env_add,
GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3,
GL_EXT_texture_filter_anisotropic, GL_EXT_texture_integer,
GL_EXT_texture_lod_bias, GL_EXT_texture_object, GL_EXT_texture_rectangle,
GL_EXT_vertex_array, GL_EXT_vertex_array_bgra,
GL_IBM_multimode_draw_arrays, GL_IBM_rasterpos_clip,
GL_IBM_texture_mirrored_repeat, GL_INGR_blend_func_separate,
GL_MESA_window_pos, GL_NV_blend_square, GL_NV_conditional_render,
GL_NV_depth_clamp, GL_NV_fog_distance, GL_NV_light_max_exponent,
GL_NV_packed_depth_stencil, GL_NV_primitive_restart,
GL_NV_texgen_reflection, GL_NV_texture_env_combine4,
GL_NV_texture_rectangle, GL_OES_EGL_image, GL_OES_read_format,
GL_S3_s3tc, GL_SGIS_generate_mipmap, GL_SGIS_texture_border_clamp,
GL_SGIS_texture_edge_clamp, GL_SGIS_texture_lod, GL_SUN_multi_draw_arrays
OpenGL ES profile version string: OpenGL ES 2.0 Mesa 19.2.8
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 1.0.16
OpenGL ES profile extensions:
GL_APPLE_texture_max_level, GL_EXT_blend_func_extended,
GL_EXT_blend_minmax, GL_EXT_compressed_ETC1_RGB8_sub_texture,
GL_EXT_depth_clamp, GL_EXT_discard_framebuffer,
GL_EXT_disjoint_timer_query, GL_EXT_draw_buffers,
GL_EXT_draw_elements_base_vertex, GL_EXT_frag_depth,
GL_EXT_map_buffer_range, GL_EXT_multi_draw_arrays,
GL_EXT_occlusion_query_boolean, GL_EXT_read_format_bgra,
GL_EXT_separate_shader_objects, GL_EXT_texture_border_clamp,
GL_EXT_texture_compression_dxt1, GL_EXT_texture_compression_s3tc,
GL_EXT_texture_compression_s3tc_srgb, GL_EXT_texture_filter_anisotropic,
GL_EXT_texture_format_BGRA8888, GL_EXT_texture_rg,
GL_EXT_texture_type_2_10_10_10_REV, GL_EXT_unpack_subimage,
GL_KHR_texture_compression_astc_sliced_3d, GL_NV_conditional_render,
GL_NV_draw_buffers, GL_NV_fbo_color_attachments, GL_NV_read_buffer,
GL_NV_read_depth, GL_NV_read_depth_stencil, GL_NV_read_stencil,
GL_OES_EGL_image, GL_OES_EGL_image_external, GL_OES_EGL_sync,
GL_OES_compressed_ETC1_RGB8_texture, GL_OES_depth24, GL_OES_depth_texture,
GL_OES_depth_texture_cube_map, GL_OES_draw_elements_base_vertex,
GL_OES_element_index_uint, GL_OES_fbo_render_mipmap,
GL_OES_get_program_binary, GL_OES_mapbuffer, GL_OES_packed_depth_stencil,
GL_OES_required_internalformat, GL_OES_rgb8_rgba8,
GL_OES_standard_derivatives, GL_OES_stencil8, GL_OES_surfaceless_context,
GL_OES_texture_3D, GL_OES_texture_border_clamp, GL_OES_texture_float,
GL_OES_texture_half_float, GL_OES_texture_npot,
GL_OES_vertex_array_object, GL_OES_vertex_half_float
408 GLX Visuals
visual x bf lv rg d st colorbuffer sr ax dp st accumbuffer ms cav
id dep cl sp sz l ci b ro r g b a F gb bf th cl r g b a ns b eat
0x021 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x022 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x26f 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x270 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x271 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x272 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x273 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x274 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x275 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x276 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x277 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x278 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x279 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x27a 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x27b 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x27c 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x27d 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x27e 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x27f 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x280 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x281 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x282 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x283 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x284 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x285 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x286 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 2 1 None
0x287 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 4 1 None
0x288 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 2 1 None
0x289 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 4 1 None
0x28a 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 2 1 None
0x28b 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 4 1 None
0x28c 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 2 1 None
0x28d 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 4 1 None
0x28e 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 2 1 None
0x28f 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 4 1 None
0x290 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 2 1 None
0x291 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 4 1 None
0x292 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 2 1 None
0x293 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 4 1 None
0x294 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 2 1 None
0x295 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 4 1 None
0x296 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 2 1 None
0x297 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 4 1 None
0x298 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 2 1 None
0x299 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 4 1 None
0x29a 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 2 1 None
0x29b 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 4 1 None
0x29c 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 2 1 None
0x29d 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 4 1 None
0x29e 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x29f 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x2a0 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x2a1 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x2a2 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x2a3 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x2a4 24 tc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x2a5 24 tc 0 24 0 r . . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x2a6 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x2a7 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x2a8 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x2a9 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x2aa 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x2ab 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x2ac 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x2ad 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x2ae 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x2af 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x2b0 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x2b1 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x2b2 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x2b3 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x2b4 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x2b5 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x2b6 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 2 1 None
0x2b7 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 4 1 None
0x2b8 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 2 1 None
0x2b9 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 4 1 None
0x2ba 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 2 1 None
0x2bb 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 4 1 None
0x2bc 24 tc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 2 1 None
0x2bd 24 tc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 4 1 None
0x2be 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 2 1 None
0x2bf 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 4 1 None
0x2c0 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 2 1 None
0x2c1 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 4 1 None
0x2c2 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 2 1 None
0x2c3 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 4 1 None
0x2c4 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 2 1 None
0x2c5 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 4 1 None
0x2c6 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 2 1 None
0x2c7 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 4 1 None
0x2c8 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 2 1 None
0x2c9 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 4 1 None
0x2ca 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 2 1 None
0x2cb 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 4 1 None
0x2cc 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 2 1 None
0x2cd 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 4 1 None
0x2ce 24 tc 0 32 0 r . . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x2cf 24 tc 0 32 0 r . . 8 8 8 8 . s 0 0 0 16 16 16 16 0 0 Slow
0x2d0 24 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x2d1 24 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 16 16 16 16 0 0 Slow
0x2d2 24 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x2d3 24 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 16 16 16 16 0 0 Slow
0x2d4 24 tc 0 32 0 r . . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x2d5 24 tc 0 32 0 r . . 8 8 8 8 . s 0 16 0 16 16 16 16 0 0 Slow
0x2d6 24 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x2d7 24 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 16 16 16 16 0 0 Slow
0x2d8 24 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x2d9 24 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 16 16 16 16 0 0 Slow
0x2da 24 tc 0 32 0 r . . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x2db 24 tc 0 32 0 r . . 8 8 8 8 . s 0 24 0 16 16 16 16 0 0 Slow
0x2dc 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x2dd 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 16 16 16 16 0 0 Slow
0x2de 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x2df 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 16 16 16 16 0 0 Slow
0x2e0 24 tc 0 32 0 r . . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
0x2e1 24 tc 0 32 0 r . . 8 8 8 8 . s 0 24 8 16 16 16 16 0 0 Slow
0x2e2 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
0x2e3 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 16 16 16 16 0 0 Slow
0x2e4 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
0x2e5 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 16 16 16 16 0 0 Slow
0x2e6 24 tc 0 32 0 r . . 8 8 8 8 . s 0 0 0 0 0 0 0 2 1 None
0x2e7 24 tc 0 32 0 r . . 8 8 8 8 . s 0 0 0 0 0 0 0 4 1 None
0x2e8 24 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 2 1 None
0x2e9 24 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 4 1 None
0x2ea 24 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 2 1 None
0x2eb 24 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 4 1 None
0x2ec 24 tc 0 32 0 r . . 8 8 8 8 . s 0 16 0 0 0 0 0 2 1 None
0x2ed 24 tc 0 32 0 r . . 8 8 8 8 . s 0 16 0 0 0 0 0 4 1 None
0x2ee 24 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 2 1 None
0x2ef 24 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 4 1 None
0x2f0 24 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 2 1 None
0x2f1 24 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 4 1 None
0x2f2 24 tc 0 32 0 r . . 8 8 8 8 . s 0 24 0 0 0 0 0 2 1 None
0x2f3 24 tc 0 32 0 r . . 8 8 8 8 . s 0 24 0 0 0 0 0 4 1 None
0x2f4 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 2 1 None
0x2f5 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 4 1 None
0x2f6 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 2 1 None
0x2f7 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 4 1 None
0x2f8 24 tc 0 32 0 r . . 8 8 8 8 . s 0 24 8 0 0 0 0 2 1 None
0x2f9 24 tc 0 32 0 r . . 8 8 8 8 . s 0 24 8 0 0 0 0 4 1 None
0x2fa 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 2 1 None
0x2fb 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 4 1 None
0x2fc 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 2 1 None
0x2fd 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 4 1 None
0x2fe 24 tc 0 24 0 r . . 8 8 8 0 . s 0 0 0 0 0 0 0 0 0 None
0x2ff 24 tc 0 24 0 r . . 8 8 8 0 . s 0 0 0 16 16 16 0 0 0 Slow
0x300 24 tc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 0 0 None
0x301 24 tc 0 24 0 r y . 8 8 8 0 . s 0 0 0 16 16 16 0 0 0 Slow
0x302 24 tc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 0 0 None
0x303 24 tc 0 24 0 r y . 8 8 8 0 . s 0 0 0 16 16 16 0 0 0 Slow
0x304 24 tc 0 24 0 r . . 8 8 8 0 . s 0 16 0 0 0 0 0 0 0 None
0x305 24 tc 0 24 0 r . . 8 8 8 0 . s 0 16 0 16 16 16 0 0 0 Slow
0x306 24 tc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 0 0 None
0x307 24 tc 0 24 0 r y . 8 8 8 0 . s 0 16 0 16 16 16 0 0 0 Slow
0x308 24 tc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 0 0 None
0x309 24 tc 0 24 0 r y . 8 8 8 0 . s 0 16 0 16 16 16 0 0 0 Slow
0x30a 24 tc 0 24 0 r . . 8 8 8 0 . s 0 24 0 0 0 0 0 0 0 None
0x30b 24 tc 0 24 0 r . . 8 8 8 0 . s 0 24 0 16 16 16 0 0 0 Slow
0x30c 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 0 0 None
0x30d 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 0 16 16 16 0 0 0 Slow
0x30e 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 0 0 None
0x30f 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 0 16 16 16 0 0 0 Slow
0x310 24 tc 0 24 0 r . . 8 8 8 0 . s 0 24 8 0 0 0 0 0 0 None
0x311 24 tc 0 24 0 r . . 8 8 8 0 . s 0 24 8 16 16 16 0 0 0 Slow
0x312 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 0 0 None
0x313 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 8 16 16 16 0 0 0 Slow
0x314 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 0 0 None
0x315 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 8 16 16 16 0 0 0 Slow
0x316 24 tc 0 24 0 r . . 8 8 8 0 . s 0 0 0 0 0 0 0 2 1 None
0x317 24 tc 0 24 0 r . . 8 8 8 0 . s 0 0 0 0 0 0 0 4 1 None
0x318 24 tc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 2 1 None
0x319 24 tc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 4 1 None
0x31a 24 tc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 2 1 None
0x31b 24 tc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 4 1 None
0x31c 24 tc 0 24 0 r . . 8 8 8 0 . s 0 16 0 0 0 0 0 2 1 None
0x31d 24 tc 0 24 0 r . . 8 8 8 0 . s 0 16 0 0 0 0 0 4 1 None
0x31e 24 tc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 2 1 None
0x31f 24 tc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 4 1 None
0x320 24 tc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 2 1 None
0x321 24 tc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 4 1 None
0x322 24 tc 0 24 0 r . . 8 8 8 0 . s 0 24 0 0 0 0 0 2 1 None
0x323 24 tc 0 24 0 r . . 8 8 8 0 . s 0 24 0 0 0 0 0 4 1 None
0x324 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 2 1 None
0x325 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 4 1 None
0x326 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 2 1 None
0x327 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 4 1 None
0x328 24 tc 0 24 0 r . . 8 8 8 0 . s 0 24 8 0 0 0 0 2 1 None
0x329 24 tc 0 24 0 r . . 8 8 8 0 . s 0 24 8 0 0 0 0 4 1 None
0x32a 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 2 1 None
0x32b 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 4 1 None
0x32c 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 2 1 None
0x32d 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 4 1 None
0x32e 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x32f 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x330 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x331 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x332 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x333 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x334 24 dc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x335 24 dc 0 32 0 r . . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x336 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x337 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x338 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x339 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x33a 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x33b 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x33c 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x33d 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x33e 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x33f 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x340 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x341 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x342 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x343 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x344 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x345 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 2 1 None
0x346 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 4 1 None
0x347 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 2 1 None
0x348 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 4 1 None
0x349 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 2 1 None
0x34a 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 4 1 None
0x34b 24 dc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 2 1 None
0x34c 24 dc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 4 1 None
0x34d 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 2 1 None
0x34e 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 4 1 None
0x34f 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 2 1 None
0x350 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 4 1 None
0x351 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 2 1 None
0x352 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 4 1 None
0x353 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 2 1 None
0x354 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 4 1 None
0x355 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 2 1 None
0x356 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 4 1 None
0x357 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 2 1 None
0x358 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 4 1 None
0x359 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 2 1 None
0x35a 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 4 1 None
0x35b 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 2 1 None
0x35c 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 4 1 None
0x35d 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x35e 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x35f 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x360 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x361 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x362 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x363 24 dc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x364 24 dc 0 24 0 r . . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x365 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x366 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x367 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x368 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x369 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x36a 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x36b 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x36c 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x36d 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x36e 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x36f 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x370 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x371 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x372 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x373 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x374 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x375 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 2 1 None
0x376 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 4 1 None
0x377 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 2 1 None
0x378 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 4 1 None
0x379 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 2 1 None
0x37a 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 4 1 None
0x37b 24 dc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 2 1 None
0x37c 24 dc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 4 1 None
0x37d 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 2 1 None
0x37e 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 4 1 None
0x37f 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 2 1 None
0x380 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 4 1 None
0x381 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 2 1 None
0x382 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 4 1 None
0x383 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 2 1 None
0x384 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 4 1 None
0x385 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 2 1 None
0x386 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 4 1 None
0x387 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 2 1 None
0x388 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 4 1 None
0x389 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 2 1 None
0x38a 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 4 1 None
0x38b 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 2 1 None
0x38c 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 4 1 None
0x38d 24 dc 0 32 0 r . . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x38e 24 dc 0 32 0 r . . 8 8 8 8 . s 0 0 0 16 16 16 16 0 0 Slow
0x38f 24 dc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x390 24 dc 0 32 0 r y . 8 8 8 8 . s 0 0 0 16 16 16 16 0 0 Slow
0x391 24 dc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x392 24 dc 0 32 0 r y . 8 8 8 8 . s 0 0 0 16 16 16 16 0 0 Slow
0x393 24 dc 0 32 0 r . . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x394 24 dc 0 32 0 r . . 8 8 8 8 . s 0 16 0 16 16 16 16 0 0 Slow
0x395 24 dc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x396 24 dc 0 32 0 r y . 8 8 8 8 . s 0 16 0 16 16 16 16 0 0 Slow
0x397 24 dc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x398 24 dc 0 32 0 r y . 8 8 8 8 . s 0 16 0 16 16 16 16 0 0 Slow
0x399 24 dc 0 32 0 r . . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x39a 24 dc 0 32 0 r . . 8 8 8 8 . s 0 24 0 16 16 16 16 0 0 Slow
0x39b 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x39c 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 0 16 16 16 16 0 0 Slow
0x39d 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x39e 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 0 16 16 16 16 0 0 Slow
0x39f 24 dc 0 32 0 r . . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
0x3a0 24 dc 0 32 0 r . . 8 8 8 8 . s 0 24 8 16 16 16 16 0 0 Slow
0x3a1 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
0x3a2 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 8 16 16 16 16 0 0 Slow
0x3a3 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
0x3a4 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 8 16 16 16 16 0 0 Slow
0x3a5 24 dc 0 32 0 r . . 8 8 8 8 . s 0 0 0 0 0 0 0 2 1 None
0x3a6 24 dc 0 32 0 r . . 8 8 8 8 . s 0 0 0 0 0 0 0 4 1 None
0x3a7 24 dc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 2 1 None
0x3a8 24 dc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 4 1 None
0x3a9 24 dc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 2 1 None
0x3aa 24 dc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 4 1 None
0x3ab 24 dc 0 32 0 r . . 8 8 8 8 . s 0 16 0 0 0 0 0 2 1 None
0x3ac 24 dc 0 32 0 r . . 8 8 8 8 . s 0 16 0 0 0 0 0 4 1 None
0x3ad 24 dc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 2 1 None
0x3ae 24 dc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 4 1 None
0x3af 24 dc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 2 1 None
0x3b0 24 dc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 4 1 None
0x3b1 24 dc 0 32 0 r . . 8 8 8 8 . s 0 24 0 0 0 0 0 2 1 None
0x3b2 24 dc 0 32 0 r . . 8 8 8 8 . s 0 24 0 0 0 0 0 4 1 None
0x3b3 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 2 1 None
0x3b4 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 4 1 None
0x3b5 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 2 1 None
0x3b6 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 4 1 None
0x3b7 24 dc 0 32 0 r . . 8 8 8 8 . s 0 24 8 0 0 0 0 2 1 None
0x3b8 24 dc 0 32 0 r . . 8 8 8 8 . s 0 24 8 0 0 0 0 4 1 None
0x3b9 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 2 1 None
0x3ba 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 4 1 None
0x3bb 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 2 1 None
0x3bc 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 4 1 None
0x3bd 24 dc 0 24 0 r . . 8 8 8 0 . s 0 0 0 0 0 0 0 0 0 None
0x3be 24 dc 0 24 0 r . . 8 8 8 0 . s 0 0 0 16 16 16 0 0 0 Slow
0x3bf 24 dc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 0 0 None
0x3c0 24 dc 0 24 0 r y . 8 8 8 0 . s 0 0 0 16 16 16 0 0 0 Slow
0x3c1 24 dc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 0 0 None
0x3c2 24 dc 0 24 0 r y . 8 8 8 0 . s 0 0 0 16 16 16 0 0 0 Slow
0x3c3 24 dc 0 24 0 r . . 8 8 8 0 . s 0 16 0 0 0 0 0 0 0 None
0x3c4 24 dc 0 24 0 r . . 8 8 8 0 . s 0 16 0 16 16 16 0 0 0 Slow
0x3c5 24 dc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 0 0 None
0x3c6 24 dc 0 24 0 r y . 8 8 8 0 . s 0 16 0 16 16 16 0 0 0 Slow
0x3c7 24 dc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 0 0 None
0x3c8 24 dc 0 24 0 r y . 8 8 8 0 . s 0 16 0 16 16 16 0 0 0 Slow
0x3c9 24 dc 0 24 0 r . . 8 8 8 0 . s 0 24 0 0 0 0 0 0 0 None
0x3ca 24 dc 0 24 0 r . . 8 8 8 0 . s 0 24 0 16 16 16 0 0 0 Slow
0x3cb 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 0 0 None
0x3cc 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 0 16 16 16 0 0 0 Slow
0x3cd 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 0 0 None
0x3ce 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 0 16 16 16 0 0 0 Slow
0x3cf 24 dc 0 24 0 r . . 8 8 8 0 . s 0 24 8 0 0 0 0 0 0 None
0x3d0 24 dc 0 24 0 r . . 8 8 8 0 . s 0 24 8 16 16 16 0 0 0 Slow
0x3d1 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 0 0 None
0x3d2 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 8 16 16 16 0 0 0 Slow
0x3d3 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 0 0 None
0x3d4 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 8 16 16 16 0 0 0 Slow
0x3d5 24 dc 0 24 0 r . . 8 8 8 0 . s 0 0 0 0 0 0 0 2 1 None
0x3d6 24 dc 0 24 0 r . . 8 8 8 0 . s 0 0 0 0 0 0 0 4 1 None
0x3d7 24 dc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 2 1 None
0x3d8 24 dc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 4 1 None
0x3d9 24 dc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 2 1 None
0x3da 24 dc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 4 1 None
0x3db 24 dc 0 24 0 r . . 8 8 8 0 . s 0 16 0 0 0 0 0 2 1 None
0x3dc 24 dc 0 24 0 r . . 8 8 8 0 . s 0 16 0 0 0 0 0 4 1 None
0x3dd 24 dc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 2 1 None
0x3de 24 dc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 4 1 None
0x3df 24 dc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 2 1 None
0x3e0 24 dc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 4 1 None
0x3e1 24 dc 0 24 0 r . . 8 8 8 0 . s 0 24 0 0 0 0 0 2 1 None
0x3e2 24 dc 0 24 0 r . . 8 8 8 0 . s 0 24 0 0 0 0 0 4 1 None
0x3e3 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 2 1 None
0x3e4 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 4 1 None
0x3e5 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 2 1 None
0x3e6 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 4 1 None
0x3e7 24 dc 0 24 0 r . . 8 8 8 0 . s 0 24 8 0 0 0 0 2 1 None
0x3e8 24 dc 0 24 0 r . . 8 8 8 0 . s 0 24 8 0 0 0 0 4 1 None
0x3e9 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 2 1 None
0x3ea 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 4 1 None
0x3eb 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 2 1 None
0x3ec 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 4 1 None
0x076 32 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x3ed 32 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x3ee 32 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x3ef 32 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x3f0 32 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x3f1 32 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x3f2 32 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x3f3 32 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x3f4 32 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x3f5 32 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x3f6 32 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x3f7 32 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x3f8 32 tc 0 32 0 r . . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x3f9 32 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x3fa 32 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x3fb 32 tc 0 32 0 r . . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x3fc 32 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x3fd 32 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x3fe 32 tc 0 32 0 r . . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x3ff 32 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x400 32 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x401 32 tc 0 32 0 r . . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
0x402 32 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
0x403 32 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
504 GLXFBConfigs:
0x077 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x078 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x079 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x07a 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x07b 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x07c 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x07d 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x07e 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x07f 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x080 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x081 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x082 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x083 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x084 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x085 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x086 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x087 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x088 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x089 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x08a 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x08b 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x08c 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x08d 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x08e 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x08f 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 2 1 None
0x090 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 4 1 None
0x091 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 2 1 None
0x092 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 4 1 None
0x093 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 2 1 None
0x094 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 4 1 None
0x095 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 2 1 None
0x096 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 4 1 None
0x097 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 2 1 None
0x098 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 4 1 None
0x099 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 2 1 None
0x09a 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 4 1 None
0x09b 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 2 1 None
0x09c 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 4 1 None
0x09d 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 2 1 None
0x09e 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 4 1 None
0x09f 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 2 1 None
0x0a0 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 4 1 None
0x0a1 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 2 1 None
0x0a2 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 4 1 None
0x0a3 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 2 1 None
0x0a4 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 4 1 None
0x0a5 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 2 1 None
0x0a6 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 4 1 None
0x0a7 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x0a8 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x0a9 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x0aa 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x0ab 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x0ac 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x0ad 24 tc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x0ae 24 tc 0 24 0 r . . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x0af 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x0b0 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x0b1 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x0b2 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x0b3 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x0b4 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x0b5 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x0b6 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x0b7 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x0b8 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x0b9 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x0ba 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x0bb 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x0bc 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x0bd 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x0be 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x0bf 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 2 1 None
0x0c0 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 4 1 None
0x0c1 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 2 1 None
0x0c2 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 4 1 None
0x0c3 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 2 1 None
0x0c4 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 4 1 None
0x0c5 24 tc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 2 1 None
0x0c6 24 tc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 4 1 None
0x0c7 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 2 1 None
0x0c8 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 4 1 None
0x0c9 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 2 1 None
0x0ca 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 4 1 None
0x0cb 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 2 1 None
0x0cc 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 4 1 None
0x0cd 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 2 1 None
0x0ce 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 4 1 None
0x0cf 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 2 1 None
0x0d0 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 4 1 None
0x0d1 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 2 1 None
0x0d2 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 4 1 None
0x0d3 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 2 1 None
0x0d4 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 4 1 None
0x0d5 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 2 1 None
0x0d6 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 4 1 None
0x0d7 24 tc 0 32 0 r . . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x0d8 24 tc 0 32 0 r . . 8 8 8 8 . s 0 0 0 16 16 16 16 0 0 Slow
0x0d9 24 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x0da 24 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 16 16 16 16 0 0 Slow
0x0db 24 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x0dc 24 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 16 16 16 16 0 0 Slow
0x0dd 24 tc 0 32 0 r . . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x0de 24 tc 0 32 0 r . . 8 8 8 8 . s 0 16 0 16 16 16 16 0 0 Slow
0x0df 24 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x0e0 24 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 16 16 16 16 0 0 Slow
0x0e1 24 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x0e2 24 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 16 16 16 16 0 0 Slow
0x0e3 24 tc 0 32 0 r . . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x0e4 24 tc 0 32 0 r . . 8 8 8 8 . s 0 24 0 16 16 16 16 0 0 Slow
0x0e5 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x0e6 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 16 16 16 16 0 0 Slow
0x0e7 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x0e8 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 16 16 16 16 0 0 Slow
0x0e9 24 tc 0 32 0 r . . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
0x0ea 24 tc 0 32 0 r . . 8 8 8 8 . s 0 24 8 16 16 16 16 0 0 Slow
0x0eb 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
0x0ec 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 16 16 16 16 0 0 Slow
0x0ed 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
0x0ee 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 16 16 16 16 0 0 Slow
0x0ef 24 tc 0 32 0 r . . 8 8 8 8 . s 0 0 0 0 0 0 0 2 1 None
0x0f0 24 tc 0 32 0 r . . 8 8 8 8 . s 0 0 0 0 0 0 0 4 1 None
0x0f1 24 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 2 1 None
0x0f2 24 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 4 1 None
0x0f3 24 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 2 1 None
0x0f4 24 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 4 1 None
0x0f5 24 tc 0 32 0 r . . 8 8 8 8 . s 0 16 0 0 0 0 0 2 1 None
0x0f6 24 tc 0 32 0 r . . 8 8 8 8 . s 0 16 0 0 0 0 0 4 1 None
0x0f7 24 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 2 1 None
0x0f8 24 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 4 1 None
0x0f9 24 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 2 1 None
0x0fa 24 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 4 1 None
0x0fb 24 tc 0 32 0 r . . 8 8 8 8 . s 0 24 0 0 0 0 0 2 1 None
0x0fc 24 tc 0 32 0 r . . 8 8 8 8 . s 0 24 0 0 0 0 0 4 1 None
0x0fd 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 2 1 None
0x0fe 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 4 1 None
0x0ff 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 2 1 None
0x100 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 4 1 None
0x101 24 tc 0 32 0 r . . 8 8 8 8 . s 0 24 8 0 0 0 0 2 1 None
0x102 24 tc 0 32 0 r . . 8 8 8 8 . s 0 24 8 0 0 0 0 4 1 None
0x103 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 2 1 None
0x104 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 4 1 None
0x105 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 2 1 None
0x106 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 4 1 None
0x107 24 tc 0 24 0 r . . 8 8 8 0 . s 0 0 0 0 0 0 0 0 0 None
0x108 24 tc 0 24 0 r . . 8 8 8 0 . s 0 0 0 16 16 16 0 0 0 Slow
0x109 24 tc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 0 0 None
0x10a 24 tc 0 24 0 r y . 8 8 8 0 . s 0 0 0 16 16 16 0 0 0 Slow
0x10b 24 tc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 0 0 None
0x10c 24 tc 0 24 0 r y . 8 8 8 0 . s 0 0 0 16 16 16 0 0 0 Slow
0x10d 24 tc 0 24 0 r . . 8 8 8 0 . s 0 16 0 0 0 0 0 0 0 None
0x10e 24 tc 0 24 0 r . . 8 8 8 0 . s 0 16 0 16 16 16 0 0 0 Slow
0x10f 24 tc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 0 0 None
0x110 24 tc 0 24 0 r y . 8 8 8 0 . s 0 16 0 16 16 16 0 0 0 Slow
0x111 24 tc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 0 0 None
0x112 24 tc 0 24 0 r y . 8 8 8 0 . s 0 16 0 16 16 16 0 0 0 Slow
0x113 24 tc 0 24 0 r . . 8 8 8 0 . s 0 24 0 0 0 0 0 0 0 None
0x114 24 tc 0 24 0 r . . 8 8 8 0 . s 0 24 0 16 16 16 0 0 0 Slow
0x115 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 0 0 None
0x116 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 0 16 16 16 0 0 0 Slow
0x117 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 0 0 None
0x118 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 0 16 16 16 0 0 0 Slow
0x119 24 tc 0 24 0 r . . 8 8 8 0 . s 0 24 8 0 0 0 0 0 0 None
0x11a 24 tc 0 24 0 r . . 8 8 8 0 . s 0 24 8 16 16 16 0 0 0 Slow
0x11b 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 0 0 None
0x11c 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 8 16 16 16 0 0 0 Slow
0x11d 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 0 0 None
0x11e 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 8 16 16 16 0 0 0 Slow
0x11f 24 tc 0 24 0 r . . 8 8 8 0 . s 0 0 0 0 0 0 0 2 1 None
0x120 24 tc 0 24 0 r . . 8 8 8 0 . s 0 0 0 0 0 0 0 4 1 None
0x121 24 tc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 2 1 None
0x122 24 tc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 4 1 None
0x123 24 tc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 2 1 None
0x124 24 tc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 4 1 None
0x125 24 tc 0 24 0 r . . 8 8 8 0 . s 0 16 0 0 0 0 0 2 1 None
0x126 24 tc 0 24 0 r . . 8 8 8 0 . s 0 16 0 0 0 0 0 4 1 None
0x127 24 tc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 2 1 None
0x128 24 tc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 4 1 None
0x129 24 tc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 2 1 None
0x12a 24 tc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 4 1 None
0x12b 24 tc 0 24 0 r . . 8 8 8 0 . s 0 24 0 0 0 0 0 2 1 None
0x12c 24 tc 0 24 0 r . . 8 8 8 0 . s 0 24 0 0 0 0 0 4 1 None
0x12d 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 2 1 None
0x12e 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 4 1 None
0x12f 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 2 1 None
0x130 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 4 1 None
0x131 24 tc 0 24 0 r . . 8 8 8 0 . s 0 24 8 0 0 0 0 2 1 None
0x132 24 tc 0 24 0 r . . 8 8 8 0 . s 0 24 8 0 0 0 0 4 1 None
0x133 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 2 1 None
0x134 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 4 1 None
0x135 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 2 1 None
0x136 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 4 1 None
0x137 0 tc 0 16 0 r . . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 None
0x138 0 tc 0 16 0 r . . 5 6 5 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x139 0 tc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 None
0x13a 0 tc 0 16 0 r y . 5 6 5 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x13b 0 tc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 None
0x13c 0 tc 0 16 0 r y . 5 6 5 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x13d 0 tc 0 16 0 r . . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None
0x13e 0 tc 0 16 0 r . . 5 6 5 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x13f 0 tc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None
0x140 0 tc 0 16 0 r y . 5 6 5 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x141 0 tc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None
0x142 0 tc 0 16 0 r y . 5 6 5 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x143 0 tc 0 16 0 r . . 5 6 5 0 . . 0 24 0 0 0 0 0 0 0 None
0x144 0 tc 0 16 0 r . . 5 6 5 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x145 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 0 0 0 0 0 0 0 None
0x146 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x147 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 0 0 0 0 0 0 0 None
0x148 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x149 0 tc 0 16 0 r . . 5 6 5 0 . . 0 24 8 0 0 0 0 0 0 None
0x14a 0 tc 0 16 0 r . . 5 6 5 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x14b 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 8 0 0 0 0 0 0 None
0x14c 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x14d 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 8 0 0 0 0 0 0 None
0x14e 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x14f 0 tc 0 16 0 r . . 5 6 5 0 . . 0 0 0 0 0 0 0 2 1 None
0x150 0 tc 0 16 0 r . . 5 6 5 0 . . 0 0 0 0 0 0 0 4 1 None
0x151 0 tc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 2 1 None
0x152 0 tc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 4 1 None
0x153 0 tc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 2 1 None
0x154 0 tc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 4 1 None
0x155 0 tc 0 16 0 r . . 5 6 5 0 . . 0 16 0 0 0 0 0 2 1 None
0x156 0 tc 0 16 0 r . . 5 6 5 0 . . 0 16 0 0 0 0 0 4 1 None
0x157 0 tc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 2 1 None
0x158 0 tc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 4 1 None
0x159 0 tc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 2 1 None
0x15a 0 tc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 4 1 None
0x15b 0 tc 0 16 0 r . . 5 6 5 0 . . 0 24 0 0 0 0 0 2 1 None
0x15c 0 tc 0 16 0 r . . 5 6 5 0 . . 0 24 0 0 0 0 0 4 1 None
0x15d 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 0 0 0 0 0 2 1 None
0x15e 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 0 0 0 0 0 4 1 None
0x15f 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 0 0 0 0 0 2 1 None
0x160 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 0 0 0 0 0 4 1 None
0x161 0 tc 0 16 0 r . . 5 6 5 0 . . 0 24 8 0 0 0 0 2 1 None
0x162 0 tc 0 16 0 r . . 5 6 5 0 . . 0 24 8 0 0 0 0 4 1 None
0x163 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 8 0 0 0 0 2 1 None
0x164 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 8 0 0 0 0 4 1 None
0x165 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 8 0 0 0 0 2 1 None
0x166 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 8 0 0 0 0 4 1 None
0x167 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x168 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x169 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x16a 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x16b 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x16c 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x16d 24 dc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x16e 24 dc 0 32 0 r . . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x16f 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x170 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x171 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x172 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x173 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x174 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x175 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x176 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x177 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x178 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x179 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x17a 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x17b 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x17c 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x17d 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x17e 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x17f 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 2 1 None
0x180 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 4 1 None
0x181 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 2 1 None
0x182 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 4 1 None
0x183 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 2 1 None
0x184 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 4 1 None
0x185 24 dc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 2 1 None
0x186 24 dc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 4 1 None
0x187 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 2 1 None
0x188 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 4 1 None
0x189 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 2 1 None
0x18a 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 4 1 None
0x18b 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 2 1 None
0x18c 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 4 1 None
0x18d 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 2 1 None
0x18e 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 4 1 None
0x18f 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 2 1 None
0x190 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 4 1 None
0x191 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 2 1 None
0x192 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 4 1 None
0x193 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 2 1 None
0x194 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 4 1 None
0x195 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 2 1 None
0x196 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 4 1 None
0x197 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x198 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x199 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x19a 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x19b 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x19c 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x19d 24 dc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x19e 24 dc 0 24 0 r . . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x19f 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x1a0 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x1a1 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x1a2 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x1a3 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x1a4 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x1a5 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x1a6 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x1a7 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x1a8 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x1a9 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x1aa 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x1ab 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x1ac 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x1ad 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x1ae 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x1af 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 2 1 None
0x1b0 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 4 1 None
0x1b1 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 2 1 None
0x1b2 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 4 1 None
0x1b3 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 2 1 None
0x1b4 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 4 1 None
0x1b5 24 dc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 2 1 None
0x1b6 24 dc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 4 1 None
0x1b7 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 2 1 None
0x1b8 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 4 1 None
0x1b9 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 2 1 None
0x1ba 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 4 1 None
0x1bb 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 2 1 None
0x1bc 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 4 1 None
0x1bd 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 2 1 None
0x1be 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 4 1 None
0x1bf 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 2 1 None
0x1c0 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 4 1 None
0x1c1 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 2 1 None
0x1c2 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 4 1 None
0x1c3 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 2 1 None
0x1c4 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 4 1 None
0x1c5 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 2 1 None
0x1c6 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 4 1 None
0x1c7 24 dc 0 32 0 r . . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x1c8 24 dc 0 32 0 r . . 8 8 8 8 . s 0 0 0 16 16 16 16 0 0 Slow
0x1c9 24 dc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x1ca 24 dc 0 32 0 r y . 8 8 8 8 . s 0 0 0 16 16 16 16 0 0 Slow
0x1cb 24 dc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x1cc 24 dc 0 32 0 r y . 8 8 8 8 . s 0 0 0 16 16 16 16 0 0 Slow
0x1cd 24 dc 0 32 0 r . . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x1ce 24 dc 0 32 0 r . . 8 8 8 8 . s 0 16 0 16 16 16 16 0 0 Slow
0x1cf 24 dc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x1d0 24 dc 0 32 0 r y . 8 8 8 8 . s 0 16 0 16 16 16 16 0 0 Slow
0x1d1 24 dc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x1d2 24 dc 0 32 0 r y . 8 8 8 8 . s 0 16 0 16 16 16 16 0 0 Slow
0x1d3 24 dc 0 32 0 r . . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x1d4 24 dc 0 32 0 r . . 8 8 8 8 . s 0 24 0 16 16 16 16 0 0 Slow
0x1d5 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x1d6 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 0 16 16 16 16 0 0 Slow
0x1d7 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x1d8 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 0 16 16 16 16 0 0 Slow
0x1d9 24 dc 0 32 0 r . . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
0x1da 24 dc 0 32 0 r . . 8 8 8 8 . s 0 24 8 16 16 16 16 0 0 Slow
0x1db 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
0x1dc 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 8 16 16 16 16 0 0 Slow
0x1dd 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
0x1de 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 8 16 16 16 16 0 0 Slow
0x1df 24 dc 0 32 0 r . . 8 8 8 8 . s 0 0 0 0 0 0 0 2 1 None
0x1e0 24 dc 0 32 0 r . . 8 8 8 8 . s 0 0 0 0 0 0 0 4 1 None
0x1e1 24 dc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 2 1 None
0x1e2 24 dc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 4 1 None
0x1e3 24 dc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 2 1 None
0x1e4 24 dc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 4 1 None
0x1e5 24 dc 0 32 0 r . . 8 8 8 8 . s 0 16 0 0 0 0 0 2 1 None
0x1e6 24 dc 0 32 0 r . . 8 8 8 8 . s 0 16 0 0 0 0 0 4 1 None
0x1e7 24 dc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 2 1 None
0x1e8 24 dc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 4 1 None
0x1e9 24 dc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 2 1 None
0x1ea 24 dc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 4 1 None
0x1eb 24 dc 0 32 0 r . . 8 8 8 8 . s 0 24 0 0 0 0 0 2 1 None
0x1ec 24 dc 0 32 0 r . . 8 8 8 8 . s 0 24 0 0 0 0 0 4 1 None
0x1ed 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 2 1 None
0x1ee 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 4 1 None
0x1ef 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 2 1 None
0x1f0 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 4 1 None
0x1f1 24 dc 0 32 0 r . . 8 8 8 8 . s 0 24 8 0 0 0 0 2 1 None
0x1f2 24 dc 0 32 0 r . . 8 8 8 8 . s 0 24 8 0 0 0 0 4 1 None
0x1f3 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 2 1 None
0x1f4 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 4 1 None
0x1f5 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 2 1 None
0x1f6 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 4 1 None
0x1f7 24 dc 0 24 0 r . . 8 8 8 0 . s 0 0 0 0 0 0 0 0 0 None
0x1f8 24 dc 0 24 0 r . . 8 8 8 0 . s 0 0 0 16 16 16 0 0 0 Slow
0x1f9 24 dc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 0 0 None
0x1fa 24 dc 0 24 0 r y . 8 8 8 0 . s 0 0 0 16 16 16 0 0 0 Slow
0x1fb 24 dc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 0 0 None
0x1fc 24 dc 0 24 0 r y . 8 8 8 0 . s 0 0 0 16 16 16 0 0 0 Slow
0x1fd 24 dc 0 24 0 r . . 8 8 8 0 . s 0 16 0 0 0 0 0 0 0 None
0x1fe 24 dc 0 24 0 r . . 8 8 8 0 . s 0 16 0 16 16 16 0 0 0 Slow
0x1ff 24 dc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 0 0 None
0x200 24 dc 0 24 0 r y . 8 8 8 0 . s 0 16 0 16 16 16 0 0 0 Slow
0x201 24 dc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 0 0 None
0x202 24 dc 0 24 0 r y . 8 8 8 0 . s 0 16 0 16 16 16 0 0 0 Slow
0x203 24 dc 0 24 0 r . . 8 8 8 0 . s 0 24 0 0 0 0 0 0 0 None
0x204 24 dc 0 24 0 r . . 8 8 8 0 . s 0 24 0 16 16 16 0 0 0 Slow
0x205 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 0 0 None
0x206 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 0 16 16 16 0 0 0 Slow
0x207 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 0 0 None
0x208 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 0 16 16 16 0 0 0 Slow
0x209 24 dc 0 24 0 r . . 8 8 8 0 . s 0 24 8 0 0 0 0 0 0 None
0x20a 24 dc 0 24 0 r . . 8 8 8 0 . s 0 24 8 16 16 16 0 0 0 Slow
0x20b 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 0 0 None
0x20c 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 8 16 16 16 0 0 0 Slow
0x20d 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 0 0 None
0x20e 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 8 16 16 16 0 0 0 Slow
0x20f 24 dc 0 24 0 r . . 8 8 8 0 . s 0 0 0 0 0 0 0 2 1 None
0x210 24 dc 0 24 0 r . . 8 8 8 0 . s 0 0 0 0 0 0 0 4 1 None
0x211 24 dc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 2 1 None
0x212 24 dc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 4 1 None
0x213 24 dc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 2 1 None
0x214 24 dc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 4 1 None
0x215 24 dc 0 24 0 r . . 8 8 8 0 . s 0 16 0 0 0 0 0 2 1 None
0x216 24 dc 0 24 0 r . . 8 8 8 0 . s 0 16 0 0 0 0 0 4 1 None
0x217 24 dc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 2 1 None
0x218 24 dc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 4 1 None
0x219 24 dc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 2 1 None
0x21a 24 dc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 4 1 None
0x21b 24 dc 0 24 0 r . . 8 8 8 0 . s 0 24 0 0 0 0 0 2 1 None
0x21c 24 dc 0 24 0 r . . 8 8 8 0 . s 0 24 0 0 0 0 0 4 1 None
0x21d 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 2 1 None
0x21e 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 4 1 None
0x21f 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 2 1 None
0x220 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 4 1 None
0x221 24 dc 0 24 0 r . . 8 8 8 0 . s 0 24 8 0 0 0 0 2 1 None
0x222 24 dc 0 24 0 r . . 8 8 8 0 . s 0 24 8 0 0 0 0 4 1 None
0x223 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 2 1 None
0x224 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 4 1 None
0x225 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 2 1 None
0x226 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 4 1 None
0x227 0 dc 0 16 0 r . . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 None
0x228 0 dc 0 16 0 r . . 5 6 5 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x229 0 dc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 None
0x22a 0 dc 0 16 0 r y . 5 6 5 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x22b 0 dc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 None
0x22c 0 dc 0 16 0 r y . 5 6 5 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x22d 0 dc 0 16 0 r . . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None
0x22e 0 dc 0 16 0 r . . 5 6 5 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x22f 0 dc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None
0x230 0 dc 0 16 0 r y . 5 6 5 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x231 0 dc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None
0x232 0 dc 0 16 0 r y . 5 6 5 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x233 0 dc 0 16 0 r . . 5 6 5 0 . . 0 24 0 0 0 0 0 0 0 None
0x234 0 dc 0 16 0 r . . 5 6 5 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x235 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 0 0 0 0 0 0 0 None
0x236 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x237 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 0 0 0 0 0 0 0 None
0x238 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x239 0 dc 0 16 0 r . . 5 6 5 0 . . 0 24 8 0 0 0 0 0 0 None
0x23a 0 dc 0 16 0 r . . 5 6 5 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x23b 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 8 0 0 0 0 0 0 None
0x23c 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x23d 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 8 0 0 0 0 0 0 None
0x23e 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x23f 0 dc 0 16 0 r . . 5 6 5 0 . . 0 0 0 0 0 0 0 2 1 None
0x240 0 dc 0 16 0 r . . 5 6 5 0 . . 0 0 0 0 0 0 0 4 1 None
0x241 0 dc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 2 1 None
0x242 0 dc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 4 1 None
0x243 0 dc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 2 1 None
0x244 0 dc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 4 1 None
0x245 0 dc 0 16 0 r . . 5 6 5 0 . . 0 16 0 0 0 0 0 2 1 None
0x246 0 dc 0 16 0 r . . 5 6 5 0 . . 0 16 0 0 0 0 0 4 1 None
0x247 0 dc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 2 1 None
0x248 0 dc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 4 1 None
0x249 0 dc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 2 1 None
0x24a 0 dc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 4 1 None
0x24b 0 dc 0 16 0 r . . 5 6 5 0 . . 0 24 0 0 0 0 0 2 1 None
0x24c 0 dc 0 16 0 r . . 5 6 5 0 . . 0 24 0 0 0 0 0 4 1 None
0x24d 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 0 0 0 0 0 2 1 None
0x24e 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 0 0 0 0 0 4 1 None
0x24f 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 0 0 0 0 0 2 1 None
0x250 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 0 0 0 0 0 4 1 None
0x251 0 dc 0 16 0 r . . 5 6 5 0 . . 0 24 8 0 0 0 0 2 1 None
0x252 0 dc 0 16 0 r . . 5 6 5 0 . . 0 24 8 0 0 0 0 4 1 None
0x253 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 8 0 0 0 0 2 1 None
0x254 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 8 0 0 0 0 4 1 None
0x255 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 8 0 0 0 0 2 1 None
0x256 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 8 0 0 0 0 4 1 None
0x257 32 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x258 32 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x259 32 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x25a 32 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x25b 32 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x25c 32 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x25d 32 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x25e 32 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x25f 32 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x260 32 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x261 32 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x262 32 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x263 32 tc 0 32 0 r . . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x264 32 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x265 32 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x266 32 tc 0 32 0 r . . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x267 32 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x268 32 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x269 32 tc 0 32 0 r . . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x26a 32 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x26b 32 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x26c 32 tc 0 32 0 r . . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
0x26d 32 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
0x26e 32 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
Are you running in a virtual machine ?
Yes
My server hardware has not arrived yet,so I am using a virtual machine to simulate parallel rendering.
Your virtual machine graphical capabilities are not enough for standard rendering. This should work using mesa. With ParaView 5.8.1, that would be: ./bin/pvserver --use-offscreen-rendering
OK,I will try it later, thank you very much for your tireless guidance.
