There is sometimes an issue on the dashboards.
Some tests fails randomly because they are “zoomed-in”. I tried to fix that by making sure “Reset Camera” is called before the screenshots, but it looks like it is noneffective in fixing this issue.
The problem is that, this issue appears quite a lot, and if more than 15 tests fails, they are not rerun and all these failures appears as true positive in the dashboard.
So if anyone has an idea of what is going on with these “zoomed-in” tests that would be great.
In the meantime I would suggest increasing the number of tests treshold needed to disable the rerun.
I am not sure what is going on with those tests. I believe restarting X or the machine usually resolves them for a time, but that isn’t long-term sustainable.
I think bumping the number of tests that fail before a rerun is reasonable. 20? 25?
