Hello Community!
This is my first ever post so please be lenient with me ![]()
I am a relatively new user of ParaView and I’ve been recently looking into Programmable Filters
I would like to see how I can access data at different timesteps. I have already had a look at the different posts in the forum, including this one, however I don’t seem to get how to achieve it apparently because I am quite new.
I have tried to build a simple example which I can share which hopefully will help you understand what I am looking for.
I have recreated this example (state file attached)
simpleExample.pvsm (358.6 KB)
https://www.kitware.com/defining-time-varying-sources-with-paraviews-programmable-source/
- In short, this uses a programmable source that generates a sphere. It also generates a list of timesteps from 0 to 99.
- The radius of the sphere is then specified as a function of the timestep which means that the sphere becomes larger or smaller, depending on the timestep.
As an extra step I am saving a new variable to host the actual radius at every timestep
output.PointData.append(radius,"Radius")
Now, to explain my goal, I would like to include a programmable Filter that within the same timestep can access and,lets say, print all the different Radius values in all different timesteps.
My code looks like the following
outInfo = self.GetOutputInformation(0)
timesteps = outInfo.Get(vtk.vtkStreamingDemandDrivenPipeline.TIME_STEPS())
for t in timesteps:
outInfo.Set(vtk.vtkStreamingDemandDrivenPipeline.UPDATE_TIME_STEP(),t)
check_time = outInfo.Get(vtk.vtkStreamingDemandDrivenPipeline.UPDATE_TIME_STEP())
print(check_time)
print(inputs[0].PointData["Radius"][0])
Apparently the code doesn’t work and its always printing the radius that is part of the selected (in the GUI) timestep.
I was hoping that the
will update the timestep meaning that anything I ask for after that, will correspond to the new updated timestep. However apparently it doesn’t work.
Any hints?
Thanks a lot in advance ![]()
-Ioannis
