Access Pipeline Browser Relationships
Say I have a pipeline setup as shown below.
I would like to run a script that operates on all the branches/children of “Solid” individually.
Is there a way to access those relationships so that I can generate handles to those sub-items, assuming I already have a handle to “Solid”?
You need to check if each of the sources in the pipeline have an input that is solid. Not really practical.
In Python, you can write
solid = FindSource('Solid')
children = [c for c in GetSources().values() if c.GetProperty('Input') and c.GetProperty('Input') == solid]
This should work in most simple cases.
I was hoping for direct access to the tree, but I suppose that’s not exposed because it’s a QT thing.
Not pretty but I can check the input of each source as recommended.
Thanks guys.
