I am attempting to access a virtual environment within paraview as described here:
Using Python Virtual environments in ParaView 5.13.0
However, when I try to start paraview with paraview --venv .venv/, The paraview instance crashes as soon as I click on the Python Shell in the GUI. The terminal output is as follows
(py3.10.11) [marc@INBDQ2HPC03N01 run1]$ paraview --venv .venv/
ParaView is using venv: .venv/
VisRTX 0.1.6, using devices:
0: NVIDIA A40 (Total: 47.7 GB, Available: 47.2 GB)
1: NVIDIA A40 (Total: 47.7 GB, Available: 47.4 GB)
error: exception occurred: Segmentation fault
My system (Red Hat Linux 8) is built with an older version of Python, and I have installed Python 3.10.11 using conda. I activated the conda enviornment in terminal before running the above paraview command.
The virtual enviornment includes pyVista and some other custom code that I wrote.
I am running Paraview v5.13.2
Any suggestions on how to correct so I can access the virtual environment within paraview?
