Hi there. I have paraview56 installed together when installing openfoam. I have a problem with set LD_LIBRARY_PATH to the folder containing NVIDIA IndeX libraries. My NVIDIA IndeX libraries are in my Downloads folder and so the command is export LD_LIBRARY_PATH=/home/keith/Downloads/nvidia-index-paraview-plugin-5.1/l/lib/, however, when I start paraview and load the plugin, the paraview lib folder does not contain the libpvNVIDIAIndeX.so. I tried to copy the file into paraview lib folder and load the plugin but it shows an error.
I downloaded the nvidia index from the link requested from nvidia website and the version is for 5.1 but my paraview version is 5.6. I am looking single desktop version . May I know is the parallel version is for server usage or rendering using multiple cores?
Hi there. I have download the Nvidia Index plugin (nvidia-index-libs-2.3.20190820-linux.tar.bz2) from paraview website https://www.paraview.org/files/dependencies/. However, when I update my LD_LIBRARY_PATH environment to the uncompressed Nvidia Index folder, and added LD_LIBRARY_PATH="$LD_LIBRARY_PATH:/home/k3ith/Downloads/nvidia-index-libs-2.3.20190820-linux/lib" to the bashrc file, I got the error.
I have try to install paraview-5.6.1/ 5.6.2 but I got error core dumped. May I know how to update the library as I do not know how to do that and above command is from Google.
Hi there. Thank you for the assistance. Finally, I got it works. Unfortunately, I got error when rendering. I will start another post to show the problem.
