Adding Python annotation to line chart plot
I am trying to add a dynamic title to my line chart plot which an mathematical expression involving time, example of title: “Velocity = 5sin(4t)”. The mathematical expression should be evaluated by Paraview. I tried to use Python Annotation but it seems that it doesn’t work with line chart.
Is it possible to add a Python annotation to Line chart plot?
I can find that the title offers only the variable ${TIME} for time but cannot do arithmetic with it.
Thank you
As a workaround, I used the following:
  • I added a render window above the line chart
  • I changed its background color to white (to match the backgroud color of the line chart window
  • I added a Python annotation filter to the render window, reduced its height to the height of the text.
That works fine for me. I hope there is a proper way to do that.
FYI, Python Annotation and other text sources will be supported in chart views starting with ParaView 5.9. The changes are available in nightly builds.
Thank you very much for the information.
