I see that superbuild_add_project_python_toml(<NAME> <ARG>...) macro is present in common-superbuild’s cmake/SuperbuildMacros.cmake but it’s never been used anywhere.
Is there any documentation supporting the usage of this macro?
I’ve been trying to add jsonschema python package, but the last version using setup.py dates to version 3.2.0 (Nov 18, 2019), which does not officially support Python 3.9.
Instead, I’ve tried adding it using superbuild_add_project_python_toml, and also adding its dependencies, which include importlib_metadata, pyrsistent and zipp.
As soon as the superbuild executes the following macro:
superbuild_add_project_python_toml(pythonzipp
PACKAGE zipp
DEPENDS pythonsetuptools)
I get the following error:
ERROR: Command errored out with exit status 1:
command: /builds/superbuild/install/bin/python3.9 /tmp/pip-standalone-pip-6qe9pac_/__env_pip__.zip/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-ioiq_eip/overlay --no-warn-script-location --no-binary :none: --only-binary :none: --no-index -- 'setuptools>=56' 'setuptools_scm[toml]>=3.4.1'
cwd: None
Complete output (2 lines):
ERROR: Could not find a version that satisfies the requirement setuptools>=56 (from versions: none)
ERROR: No matching distribution found for setuptools>=56
Thank you ![]()
