Recently I’ve been trying to use the runTimePostProcessing in OpenFOAM, and I cannot get any working paraview build out of the OpenFOAM packages. LLVM fails to build, so then no mesa/VTK/pv.
I’ve been using the superbuild for several years; I’m always able to get a working build, x86, ARM, graphics card/headless - great tool! So I tried build the OpenFOAM visualization module using an existing paraview superbuild:
But I just get the errors at the end of this post. I am not quite sure what “remotingCore” is, and I can’t figure out any flags I could use to build this component?
Any general advice on how best to get runTimePostProcessing working? Am I crazy trying to use an external superbuild for this? Superbuild options (graphic-less ARM64) are below for reference:
CMake Error at CMakeLists.txt:66 (find_package):
Found package configuration file:
/data/paraview/5.7.0/lib/cmake/paraview-5.7/paraview-config.cmake
but it set ParaView_FOUND to FALSE so package "ParaView" is considered to
be NOT FOUND. Reason given by package:
Could not find the ParaView package with the following required components:
RemotingCore.
Do not use the superbuild unless you need specific libs that you do now want to build yourself. If you need osmesa and your distribution does not provide a package, you may want to use the superbuild in that case.
Thanks for the answers. The superbuild has given me working builds on ARM64 (5.7.0, 5.9.1). My issue is how to get a build that will allow for OpenFOAM’s runTimePostProcessing (I guess this is called “in situ”)
I’m trying to build the “CATALYST_RENDERING” edition, but I get contradictory errors. VTK is missing IOFFMPEG, but if I build FFMPEG, catalyst is incompatible with IO support. Perhaps a bug, but my guess is I am simply unaware of some flags I should be setting?
CMake Error at /data/pvsuper/sb_5.10.0/install/lib/cmake/paraview-5.10/paraview-config.cmake:169 (find_package):
/data/pvsuper/sb_5.10.0/install/lib/cmake/paraview-5.10/vtk/vtk-config.cmake
but it set VTK_FOUND to FALSE so package "VTK" is considered to be NOT
Could not find the VTK package with the following required components:
IOFFMPEG.
ParaView is configured without I/O support (via the CATALYST_RENDERING
edition) which is incompatible with the request for FFmpeg support (via the
`PARAVIEW_ENABLE_FFMPEG` configure option)
I know this was a year ago, but I ran into the same issue and solved it with the following for anyone else out there looking for an answer. Anyway, here is how I compiled ParaView with OpenFOAM’s make script. You could achieve pretty much the same thing using the superbuild and cmake. These are my notes from a year ago:
With OF2112 and PV5.10, need to manually enable ffmpeg in PV due to OF catalyst requiring it. Added these Cmake variables:
I also had to add quotes to the variable in line 164 of the following file:
./ThirdParty-v2112/platforms/linuxARM64Gcc/ParaView-5.10.0/lib/cmake/paraview-5.10/paraview-config.cmake
Separately, I don’t think 5.11.0 is compatible with OpenFOAM’s catalyst plugin.
