Animating a collection
Here is my pvd file:
<?xml version="1.0" encoding="utf-8"?>
<VTKFile type="Collection" version="1.0" byte_order="LittleEndian" compressor="vtkZLibDataCompressor">
  <Collection>
    <DataSet timestep="0.0" part="0" file="mvtkcollection1-1.vtu"/>
    <DataSet timestep="0.1" part="0" file="mvtkcollection1-2.vtu"/>
    <DataSet timestep="0.2" part="0" file="mvtkcollection1-3.vtu"/>
    <DataSet timestep="0.3" part="0" file="mvtkcollection1-4.vtu"/>
    <DataSet timestep="0.4" part="0" file="mvtkcollection1-5.vtu"/>
    <DataSet timestep="0.5" part="0" file="mvtkcollection1-6.vtu"/>
    <DataSet timestep="0.6" part="0" file="mvtkcollection1-7.vtu"/>
    <DataSet timestep="0.7" part="0" file="mvtkcollection1-8.vtu"/>
    <DataSet timestep="0.8" part="0" file="mvtkcollection1-9.vtu"/>
    <DataSet timestep="0.9" part="0" file="mvtkcollection1-10.vtu"/>
    <DataSet timestep="1.0" part="0" file="mvtkcollection1-11.vtu"/>
  </Collection>
</VTKFile>
Each of the files exist, and can be visualized. My question is: how do I animate the collection?
I try to do the obvious thing,
but I got a hard crash.
You shouldn’t have to open the Animation view. Maybe a place to start is with ParaView 5.10. There are now example .pdf files included with the download. Start with those? They are in File/ Open/ Examples/ vtk/ xml/ parallelUnstrctured. Just open timeBasedUnstructured.pvd, and play it forward and backward.
Are you saying collections only work with 5.10?
OK, I’ve got 5.10. I loaded the file, but HOW do I play it?
You mean ‘pvd’ files, not ‘pdf’ files, correct?
Ok, I think I’ve got it: with 5.10 the play buttons just work, and no settings need to be twiddled. Thanks for your help.
Good. And to quote a friend, Ken Moreland, I blame spell correct. Yes, .pvd files.
