When I imported a set of VTK files to generate an animation, I found that only one frame was displayed during the animation run, and the others were not displayed, so I had to switch manually.
Are you sure all files have the same set of data arrays? From the image you attached looks like the name of the velocity array is different between files. The (?) is shown when an array is chosen but no longer available in the dataset.
