I have a problem getting my FLUENT data into paraview. I tried different methods but nothing works.
Reading the .cas file from FLUENT directly doesn’t work. After a few minutes loading paraview crashes without an error.
I also tried encas gold (EnSight Case Gold in Fluent) with every combination.
- Node ASCII
- Node Binary
- Cell Center ASCII
- Cell Center Binary
If I load the data in ParaView (EnSight Reader) I can see my data under “Cell Arrays” or “Point Arrays”, but if I press the “Apply” button, I always get this error:
ERROR: In C:\glr\builds\paraview\paraview-ci\build\superbuild\paraview\src\VTK\IO\EnSight\vtkEnSightGoldBinaryReader.cxx, line 348
vtkEnSightGoldBinaryReader (0000026D0C5BCAF0): Invalid part id; check that ByteOrder is set correctly.
ERROR: In C:\glr\builds\paraview\paraview-ci\build\superbuild\paraview\src\VTK\IO\EnSight\vtkEnSightReader.cxx, line 297
vtkEnSightGoldBinaryReader (0000026D0C5BCAF0): error reading geometry file
ERROR: In C:\glr\builds\paraview\paraview-ci\build\superbuild\paraview\src\VTK\Common\ExecutionModel\vtkExecutive.cxx, line 753
vtkCompositeDataPipeline (0000026D26DC16B0): Algorithm vtkEnSightGoldBinaryReader(0000026D0C5BCAF0) returned failure for request: vtkInformation (0000026D11A24210)
Debug: Off
Modified Time: 66334262
Reference Count: 1
Registered Events: (none)
Request: REQUEST_DATA
FORWARD_DIRECTION: 0
ALGORITHM_AFTER_FORWARD: 1
FROM_OUTPUT_PORT: 0
The model still loads but I can’t see the e.g. the velocity, I only see “vtkBlockColors” and I can’t change it.
So, do I need an additional software package for the errors? I’m using ParaView 5.9.0, but I also tried it on other versions. I’m using Windows Server 2022 Standard.
Kind Regards,
Andreas
