This seems like a fairly obvious thing to want to do during development. I have a client-side SMProxy object in Python, and I’d like to ask the server-side vtkObject to PrintSelf(), for debugging purposes.
Adding a <Property name="Print" command="Print" /> to the proxy definition and then calling that using vtkSMProxy::InvokeCommand("Print") is one of the ways to do it.
Hmm, this doesn’t seem to work. vtkObjectBase::Print(…) needs a parameter, doesn’t it?
Also, if this did work, it would call print on the SMProxy, not on the SIProxy-wrapped vtkObject?
Hmm actually no, I got confused, this should in theory work.
Seems like vtkClientServerStream wrapping has specially handled Print to return the result as reply.
// from vtkObjectBaseClientServer.cxx
if (!strcmp("Print",method) && msg.GetNumberOfArguments(0) == 2)
std::ostringstream buf_with_warning_C4701;
op->Print(buf_with_warning_C4701);
resultStream.Reset();
resultStream << vtkClientServerStream::Reply
<< buf_with_warning_C4701.str().c_str()
<< vtkClientServerStream::End;
return 1;
Not entirely sure why that was done.
A workaround is to add a new method to your vtkObject subclass that simply calls Print and expose that one instead in the XML.
