I have a dataframe that is of the following format
ID t_0 t_1 t_2 t_n
0 . . . .
m
and I want to read and append each column array as a field at their respective time-step to an existing set of vtu files (vtkXMLUnstructuredGrid) so that I can build further filters in paraview and create a pipeline.
Part1 - Using the Programmable Filter
frame = pd.read_hdf('/path/to/file/frame.h5', 'table', mode='r')
ts = self.GetInputDataObject(0,0).GetInformation().Get(vtk.vtkDataObject.DATA_TIME_STEP())
t = int(ts)
wantedArray = frame.filter(['t_{}'.format(t)], axis=1)
from numpy import array
a = array(wantedArray)
output.PointData.append(a, "newField")
The above script works. However, as the dataframe is quite large (~10 GB) it makes the whole process slow when I move to the next time step because the dataframe is read again while updating the pipeline. Is there a way to read the large .h5 file once and store it in the memory and access the data?
Part 2 - Using paraview's python console
>>> view = GetActiveView()
>>> t = int(view.ViewTime)
>>> inputSource = GetActiveSource()
>>> inputData = servermanager.Fetch(inputSource)
>>> nPoints=inputData.GetNumberOfPoints()
>>> newField=paraview.vtk.vtkFloatArray()
>>> newwField.SetNumberOfValues(nPoints)
>>> newField.SetName("newField")
>>> for k in range(nPoints):
...newField.SetValue(k, a[k])
>>> inputData.GetPointData().AddArray(newField)
The above code creates the correct field and I am able to access the values in the python console with
inputData.GetPointData().GetArray("newField").GetValue()
The problem is that I am not able to visualize this array in the render view and process it further with other filters. How do I get this array back to show up in the render view (gui) as a field in the drop down list?
I tried few things like Show(), Render() but did not work. I also tried the follwing snippet:
t = TrivialProducer()
filter = t.GetClientSideObject()
filter.SetOutput(inputData)
t.UpdatePipeline()
but this throws the following error:
AttributeError: 'NoneType' object has no attribute 'SetOutput'
Any alternate suggestions are also welcome. I want to implement this as efficiently as possible!
