apply appendattributes to several med files
Using a loop python script applied to several *. med file
I want to open , select a specific parameter, apply calculator filter and at last a wrap filter
The main problem lay with the use of appenattibute filter. Indeed in my script, i don’t manage to apply it, to all med files :
import pvsimple
pvsimple.ShowParaviewView()
# trace generated using paraview version 5.9.0
#### import the simple module from the paraview
from pvsimple import *
#### disable automatic camera reset on 'Show'
pvsimple._DisableFirstRenderCameraReset()
a = []
b = [None]
d = [None]
e = [None]
f = [None]
g = [None]
h = [None]
p = [None]
for i in range(3):
	# create a new 'MED Reader'
	if i < 10:
		b.append('rbassin0000%d' % i + 'med')
		d.append('rbassin0000%d' % i + 'med' + 'Display')
		b[i] = MEDReader(registrationName='rbassin0000' + str(i) + '.med', FileName='/home/vesvard211/maillage/rbassin0000' + str(i) + '.med')
	else:
		d.append('rbassin000%d' % i + 'med' + 'Display')
		b[i] = MEDReader(registrationName='rbassin000' + str(i) + '.med', FileName='/home/vesvard211/maillage/rbassin000' + str(i) + '.med')
# get animation scene
	animationScene1 = GetAnimationScene()
# update animation scene based on data timesteps
	animationScene1.UpdateAnimationUsingDataTimeSteps()
	SetActiveSource(b[i])
# Properties modified on bassin0med
	b[i].AllArrays = ['TS0/bassin/ComSup1/Mdepl@@][@@P1']
# get active view
# show data in view
	d[i] = Show(b[i], renderView1, 'UnstructuredGridRepresentation')
# trace defaults for the display properties.
	d[i].Representation = 'Surface'
# reset view to fit data
	renderView1.ResetCamera()
# get the material library
	materialLibrary1 = GetMaterialLibrary()
# update the view to ensure updated data information
	renderView1.Update()
# set scalar coloring
	ColorBy(d[i], ('POINTS', 'Mdepl', 'Magnitude'))
# rescale color and/or opacity maps used to include current data range
	d[i].RescaleTransferFunctionToDataRange(True, False)
# show color bar/color legend
	d[i].SetScalarBarVisibility(renderView1, True)
# get color transfer function/color map for 'Mdepl'
	mdeplLUT = GetColorTransferFunction('Mdepl')
# get opacity transfer function/opacity map for 'Mdepl'
	mdeplPWF = GetOpacityTransferFunction('Mdepl')
# set active source
SetActiveSource(print(b[0]))
SetActiveSource(print(b[1]))
SetActiveSource(print(b[2]))
# create a new 'Append Attributes'
appendAttributes1 = AppendAttributes(registrationName='AppendAttributes1', Input=[print(b[i])])
# show data in view
appendAttributes1Display = Show(appendAttributes1, renderView1, 'UnstructuredGridRepresentation')
appendAttributes1Display.Representation = 'Surface'
for j in range(3):
# create a new 'Calculator'
	k = j - 1
	e.append("calculator%d" % j)
	e[j] = Calculator(registrationName='calculator%d' % j, Input=appendAttributes1)
# Properties modified on calculator1
	if j == 0:
		e[j].ResultArrayName = 'M%d' % j
		e[j].Function = 'Mdepl'
	else:
		e[j].Function = 'M%d' % k + '+' + 'Mdepl_input_%d' % j
# create a new 'Warp By Vector'
	f.append("warpByVector%d" % j)
	g.append("warpByVector%d" % j + "Display" )
	f[j] = WarpByVector(registrationName="warpByVector%d" % j, Input=[print('calculator%d' % j)])
# Properties modified on warpByVector1
	f[j].ScaleFactor = 5000
# show data in view
	g[j] = Show(f[j], renderView1, 'UnstructuredGridRepresentation')
	g[j].Representation = 'Surface'
# hide data in view
	Hide(b[j], renderView1)
	ColorBy(g[j], ('POINTS', 'M%d' % j, 'Magnitude'))
	g[j].RescaleTransferFunctionToDataRange(True, False)
	g[j].SetScalarBarVisibility(renderView1, True)
	mdeplLUT = GetColorTransferFunction('M%d' % j)
	mdeplPWF = GetOpacityTransferFunction('M%d' % j)
# Apply a preset using its name. Note this may not work as expected when presets have duplicate names.
	mdeplLUT.ApplyPreset('Rainbow Uniform', True)
#### saving camera placements for all active views
# current camera placement for renderView1
renderView1.CameraPosition = [0.007254707374675282, -0.49900709211761174, 0.46427352241737563]
renderView1.CameraFocalPoint = [1.2015019498213393e-06, -6.744833810744443e-08, 0.15000010536583305]
renderView1.CameraViewUp = [0.011771325523215763, 0.5330006202259059, 0.8460329631487336]
renderView1.CameraParallelScale = 0.15264365376518474
see in attach file the screen shot :
question1.pdf (97.4 KB)
regards
AppendAttributes take several inputs: give it the full list of input readers as Input instead of the single-element list as you do.
thanks for your answer. I understand the concept but i’m wondering the way to code it
regards
Well, I mean something like
AppendAttributes(registrationName='AppendAttributes1', Input=b)
Thanks
But the main problem links to the Input parameter. Indeed i need to address all the b(i) files, and when i try
Input=b
```it doesn't work too
Regards
Well, something wrong happen in your script then. Try with a simpler script, and if you do not get it please provide error messages.
For info, the following works just fine:
spheres = []
spheres.append(XMLPolyDataReader(registrationName='sphere_0.vtp', FileName=['/tmp/sphere/sphere_0.vtp']))
spheres.append(XMLPolyDataReader(registrationName='sphere_1.vtp', FileName=['/tmp/sphere/sphere_1.vtp']))
spheres.append(XMLPolyDataReader(registrationName='sphere_2.vtp', FileName=['/tmp/sphere/sphere_2.vtp']))
# create a new 'Append Datasets'
appendDatasets1 = AppendDatasets(registrationName='AppendDatasets1', Input=spheres)
UpdatePipeline(time=0.0, proxy=appendDatasets1)
Thank you for helping
the appendattribute function is working :
import pvsimple
medFiles = []
medDisplays = []
e = []
f = []
g = []
h = [None]
p = [None]
l = [None]
for i in range(3):
	if i < 10:
		medFiles.insert(i,MEDReader(registrationName='rbassin0000' + str(i) + '.med', FileName='/home/vesvard211/maillage/rbassin0000' + str(i) + '.med' ))
	else:
		medFiles.insert(i,MEDReader(registrationName='rbassin000' + str(i) + '.med', FileName='/home/vesvard211/maillage/rbassin000' + str(i) + '.med'))
	medFiles[i].AllArrays = ['TS0/bassin/ComSup1/Mdepl@@][@@P1']
# get active view
# show data in view
	medDisplays.insert(i,Show(medFiles[i], renderView1, 'UnstructuredGridRepresentation'))
	medDisplays[i].Representation = 'Surface'
	ColorBy(medDisplays[i], ('POINTS', 'Mdepl', 'Magnitude'))
	medDisplays[i].RescaleTransferFunctionToDataRange(True, False)
	medDisplays[i].SetScalarBarVisibility(renderView1, True)
for j in range(3):
	SetActiveSource(medFiles[j])
appendAttributes1 = AppendAttributes(registrationName='AppendAttributes1', Input=medFiles)
# show data in view
But i’ve got a last problem linked to the selection of the deplacement value of my med file :
it’s not working in this script. I 'm wondering why
Regards
PS med file example is located here : https://unicloud.unicaen.fr/index.php/s/et98DmfRAKNpi8b
In fact it seems that the loop or the list induce a reader failure :
Please try to open new posts for new problems, this help a lot to understand while reading the thread :slight_smile:
Also can you try to isolate your new issue? I mean create the minimal script to reproduce, so it is easier to understand which line is faulty
Thanks for your advice
So i close this post and i open a new one dedicated to the medreader problem
Regards
