I would like to know if it is possible to colour different facets of a mesh (STL) individually in ParaView?
The context is that I have an STL file with N (>1000s) facets and an associated text file complete with N RGB colour values. Is it possible to apply the RGB value to each corresponding facet?
Thank you Mathieu for your quick reply! Forgive my ignorance, but where would I find “Map Scalars”? I have attached a screenshot of my view for reference.
I unchecked map scalars, but am unsure about how exactly to apply the RGB values to the rendering. I have tried to add the RGB CSV to ParaView but an unsure about how to map it to the mesh (the files I am using are attached: test.stl and test_facecolors.csv)
Does ParaView support RGB values in the attribute bytes of every triangle? RE: https://en.wikipedia.org/wiki/STL_(file_format)#Color_in_binary_STL
I have tried this approach according to the VisCam and SolidView spec (see attached test_rgb_binary.stl) but not had any luck so far. Any help would be appreciated!
Thank you Mathieu, yes this is exactly the desired output, thank you for your help!
As you said, I am currently separating the colour information from the stl file, would there be a better or recommended way to store this data to combine the two?
