Good afternoon,
I am using ParaView now for over a year but still struggle with one significant issue: I run MHD simulations on a daily basis with one code and generate vtu output that I analyze with ParaView. I built a complex pipeline doing coordinate transformations for vector fields, computing derived quantities from the output etc. Building the pipeline takes me > 3 hrs!
The problem is that when I run my code again with new parameters I have to build the pipeline again because the data files output is not identical. I usually run with my code with a different number of cores (each of which writes out part of the output vtu data in a separate file) depending of whether I run the code locally or on our cluster. I ususally also have a different number of iterations/timesteps before convergence, so I have a different number of datafiles even if use the same computational mesh.
So far I was only partially successful to reuse my pipelines on different runs of the same code:
- I linked (and renamed) one temporal snapshot to a separate directory and then was able to read-in that single time step by using the feature “only import data from this directory”. So this works for a fixed number of cores (=fixed number of output files) and one single time step. I had to generate the same pipeline for, say 8 and 60 cores. I cannot study the temporal evolution with this pipeline.
- I tried to merge all the vtu output (from different I/O cores and different time steps) into on h5-file and build the whole pipeline based on this h5-file. However, also this approach fails when trying to load that pipeline on data from a new run as the different number of timesteps in a run is unavoidable for my implicit code.
At this point I don’t know whether I should use ParaView any longer. The data analysis and rendering works very well but I cannot the time to re-build complex pipelines (pvsm state files) everytime I want to analyze data from a new run of the same code. I simply don’t have the time for that and don’t know whether this issue can be fixed somehow.
Thanks a lot for your time and feedback!
