Hi, I have a domain with a length of 21m and a width of 35mm. Because of very small width it is hard to see the various features of the domain. If I zoom it then I can not see the whole length. How can I change the scale setting so that the domain will look much wider while showing the whole 21m length. I have attached an image to better explain the situation. Thank you.
That is currently a topic of discussion. https://gitlab.kitware.com/paraview/paraview/-/issues/21130
A workaround is to either use the Transform filter or on the Properties tab, I believe Advanced, you will find a Transform block. Use the Scale controls.
