Hello all,
My goal is to have an object (a compass) that I can put at the top of my ParaView animation to
always show the direction of view.
I’ve tried a couple of ways I thought this might work, but have yet to find a workable solution.
First I tried to put the compass in it’s own RenderView and use a LiveProgrammableSource with a quick-timer rerender to copy the camera orientation (but not location) from one view to the other.  And while I can get the orientation copied once, it doesn’t work on a continual basis.
(For this I used the timing script from: update automatic data input)
So then I thought a better solution might just be to translate the compass to “follow” the camera,
and reposition it in front of the camera (and up a little) whenever the camera moves.  For this,
I can’t use a source, so I use the ProgrammableFilter, which doesn’t have the “Live” option.
So I can gert this to work – once – but I don’t know a way to make it happen all the time.  Ideally
I’d like it to work continually, including when I move the camera with the mouse in the RenderView.
But I’d be happy if I could figure out a way to trigger the ProgrammableFilter on an ongoing basis.
Is there a way to use the ResquestUpdateExtent script option?
ASIDE: as I mentioned, my ideal would be to have a script that executes while I’m changing
the camera view with the mouse, but even the LiveProgrammableSource freezes whenever
the mouse is engaged.
FYI: here’s the “Script” portion that I’m using for the PrrogrammableFilter to move my compass:
# moveToCam.py
from paraview import servermanager
from vtk.vtkCommonTransforms import vtkTransform
from vtk.vtkFiltersGeneral import vtkTransformPolyDataFilter
import operator
import numpy as np
pdi = self.GetPolyDataInput()
pdo = self.GetPolyDataOutput()
# Get information about the main (current) camera
view = servermanager.GetRenderView()
camera = view.GetActiveCamera()
# Calculate a location that's in front of the camera (with minor adjustments)
camLocation = camera.GetPosition()
dirVector = tuple(map(operator.sub, camera.GetFocalPoint(), camLocation))
normDir = dirVector / np.linalg.norm(dirVector)
newLocation = camLocation + normDir * 100 + [0.0, -15.0, 0.0]
# Create a tranformation object that moves objects to be in front of the camera
#   as well as doing a scaling operation.
transform = vtkTransform()
transform.Translate(newLocation)
transform.Scale(10.0, 10.0, 10.0)
# Create the poly data filter that uses the above transform
transformPD = vtkTransformPolyDataFilter()
transformPD.SetTransform(transform)
transformPD.SetInputData(pdi)
transformPD.Update()
# Apply the transform to the output (via the Poly Data Filter)
pdo.ShallowCopy(transformPD.GetOutput())
Thanks,
Bill
