Dear users,
from a parallel simulation with many partitions I get a separate .vtu file from each processor and for each time step. My goal is to automate the generation of .vtk multiblock files (so basically grouping my files into the different time steps).
All files have the naming convention:
name_PPPPTTTTT>.vtu
with P as the (zero padded) partition number and T as the (zero padded) timestep number.
Is there a simple way of achieving this grouping?
So far I was able to load all of the files in to an array. But the grouping did not work as expected.
from paraview.simple import *
import fnmatch
import os
# from https://stackoverflow.com/questions/431684/how-do-i-change-the-working-directory-in-python/13197763#13197763
class cd:
"""Context manager for changing the current working directory"""
def __init__(self, newPath):
self.newPath = os.path.expanduser(newPath)
def __enter__(self):
self.savedPath = os.getcwd()
os.chdir(self.newPath)
def __exit__(self, etype, value, traceback):
os.chdir(self.savedPath)
def getFiles(directory, pattern = "P*.vtu"):
return fnmatch.filter(os.listdir(directory), pattern)
def getFileIndizes(directory):
return [file.split("_")[1].split(".")[0] for file in getFiles(directory)]
def getPartitionList(directory):
return list({int(index[0:4]) for index in getFileIndizes(directory)})
def getTimeStepList(directory):
return list({int(time[4:]) for time in getFileIndizes(directory)})
def loadFile(fileName):
return XMLUnstructuredGridReader(FileName=fileName)
if __name__ == "__main__":
loadedFiles = [[]]
directory = os.path.join('.', 'Paraview')
# load file names in array: [ [p1t1, p2t1, p3t1 ,...], [p1t2, p2t2, p3t2, ...] ]
for tIndex, time in enumerate(getTimeStepList(directory)):
loadedFiles.append([])
for partition in getPartitionList(directory):
currentFile = fnmatch.filter(os.listdir(directory), f"P*_{partition:04d}{time:05d}.vtu")
with cd(directory):
loadedFiles[tIndex].append(loadFile(currentFile))
loadedFiles.pop(-1)
groups = []
for timeStep in loadedFiles:
groups.append(GroupDatasets(Input=timeStep))
for group in groups:
SaveData(os.path.join(directory, 'output.vtm'), proxy=group, PointDataArrays=['Displacements', 'Principal Stress', 'Stress/Strain'],
Writetimestepsasfileseries=1)
