Dear all,
I have a naive question which has probably been addressed in the past, but I was not able to find any reference about. When I import the following XDMF file in Paraview
<Topology TopologyType="3DCORECTMesh" NumberOfElements=" 81 41 21"/>
<Geometry GeometryType="ORIGIN_DXDYDZ">
<DataItem Name="Origin" Dimensions="3" NumberType="Float" Precision="4" Format="XML">
0.000000 0.000000 0.000000
</DataItem>
<DataItem Name="Spacing" Dimensions="3" NumberType="Float" Precision="4" Format="XML">
0.025000 0.025000 0.025000
</DataItem>
</Geometry>
</Grid>
the x- and z-axis are erroneously swapped. I guess this is not a visualization problem but a wrong data import, as in the “Information” tab I read
X Extent: 0 to 20 (should be 0 to 80)
Z Extent: 0 to 80 (should be 0 to 20)
X Range: 0 to 0.5 (should be 0 to 2)
Z Range: 0 to 2 (should be 0 to 0.5)
Any hint? I’m using Paraview 5.7.0 on Ubuntu 18.04
Thanks in advance
