Best Way to Read (X-Point Gyrokinetic Code, ADIOS2 BP) Timeseries Data with Mesh Specified in Another File
I’ve tried a few approaches to read ADIOS2 BP format timeseries data from the X-Point Gyrokinetic Code into Paraview for visualization (I’d like to eventually play with VR, and I’d like to represent the timeseries data perhaps through an animation or something). Right now, I’m struggling to conceptualize the best way to associate mesh data (written to an ADIOS2 BP “file” (really a folder) called xgc.mesh.bp). The timeseries data is a variable in files with the naming scheme xgc.3d.XXXXX.bp, where XXXXX refers to the timestep.
For background, XGC uses a simple cylindrical coordinate system (R, Z, phi → toroidal angle), and data is (often) computed on a 3D mesh that is unstructured in R,Z planes and evenly spaced / structured in the phi / toroidal angle direction (think - donut shaped mesh, with unstructured mesh cross sections that are cut out of the donut in even intervals in such a way that the knife passes through the hole in the center in order to get the “poloidal plane” cross section). This data is written out to BPs as a 2D array, with the first dimension containing data associated with all of a poloidal plane’s / cross section’s unstructured mesh points, and the second dimension representing the poloidal plane index (again, these are evenly spaced in phi from 0-2pi).
So, with that, I need to be able to associate this R,Z data with mesh point indices, and compute an evenly spaced phi, then transform to (x,y,z) coordinates and associate these mesh locations to the data in the timeseries BP files for use in paraview. From my reading, I see a few options:
  • Write an XML file into the BP folder for each BP (later, if this works, specify it as an attribute written to the BP file) that specifies this data as a VTK “unstructured grid”. It seems like in this case, I have to include the mesh point R,Z,phi or x,y,z locations in a text array of values - which would contribute quite a bit of bloat / duplication (I have ~1500 timestep BP files, and will likely produce more).
  • Write some sort of top-level (in the base folder rather than within each BP file) specification file (XML? XDMF?) that I don’t understand well at all, and I’m not sure where I can read up on this.
  • Read data and rewrite to a file that VTK inherently understands (probably, with the mesh data saved into each file), which would be impractical since I have very large datasets.
  • Write a plugin in python that reads from the xgc.mesh.bp file and computes / loads triangle data as the data is loaded from the timeseries file. I have an example that ChatGPT helped me create below (seems right, but I’m not fully sure), but it’s not clear to me how to leverage the ADIOS2 that Paraview is using under the hood. I’ve attempted to use pip to install adios2 into the correct folder as in here, but it seems that the pip adios2 library is potentially broken (I can’t import adios2 on my miniconda install - I have to use conda to install to get an importable install - nor is it able to be imported from the paraview python interpreter shell). I’ve also tried installing to my miniconda install using conda, then copying the package folder manually to the folder where paraview stores its packages internally, but I can’t import the package properly that way either.
So overall, I’m looking for:
  • What’s the best way to get the data into paraview, associating the R,Z poloidal plane mesh with the data contained in xgc.mesh.bp?
  • If a plugin is potentially the best method, how would I go about getting a usable adios2 python package working so I can use my below plugin? Does the plugin below seem ok for this use?
Thanks all.
Plugin:
XGC Reader Plugin
from paraview.util.vtkAlgorithm import smproxy, smproperty, smdomain
import numpy as np
import adios2
import vtk
import os
from vtk.util import numpy_support as ns
@smproxy.reader(name="XGCReader", label="XGC BP Reader",
                extensions="bp", file_description="Read XGC ADIOS2 timeseries files (xgc.3d..., xgc.f3d...)")
class XGCReader(vtk.vtkAlgorithm):
    def __init__(self):
        super().__init__()
        self.SetNumberOfInputPorts(0)
        self.SetNumberOfOutputPorts(1)
        self.filename = None
        self.rz_mesh = None
        self.n_phi = 0
        self.phi_vals = None
        self.triangles = None
    @smproperty.stringvector(name="FileName")
    @smdomain.filelist()
    def SetFileName(self, fname):
        self.filename = fname
        self.Modified()
    def RequestInformation(self, request, inInfo, outInfo):
        return 1
        # Extract timestep number to open mesh file
        timestep = int(self.filename.split('.')[-2])   # relies on the naming scheme "xgc.{3d,f3d,2d,f2d}.XXXXX.bp"
        # Read mesh (once)
        if self.rz_mesh is None:
            with adios2.open("xgc.mesh.bp", "r") as f:
                self.rz_mesh = np.array(f.read("rz"))  # shape: [npoints, 2]
            with adios2.open(self.filename, "r") as f:
                tmp_data = f.read("dpot")              # just read an array of data that's going to be present - dpot is NOT present in any
                self.n_phi = tmp_data.shape[1]         # other type of file, but that usually doesn't have the same layout of data anyway
                self.phi_vals = np.linspace(0, 2 * np.pi, self.n_phi, endpoint=False)
                self.triangles = np.array(f.read("nd_connect_list"))  # shape: [ntris, 3]
        n_points_2d = self.rz_mesh.shape[0]
        n_phi = self.n_phi
        # Build 3D grid
        points = vtk.vtkPoints()
        for i_phi, phi in enumerate(self.phi_vals):
            cos_phi, sin_phi = np.cos(phi), np.sin(phi)
            for r, z in self.rz_mesh:
                x = r * cos_phi
                y = r * sin_phi
                points.InsertNextPoint(x, y, z)
        # Build triangles
        cells = vtk.vtkCellArray()
        for i_phi in range(n_phi):
            offset = i_phi * n_points_2d
            for tri in self.triangles:
                ids = [int(idx + offset) for idx in tri]
                triangle = vtk.vtkTriangle()
                for j in range(3):
                    triangle.GetPointIDs().SetID(j, ids[j])
                cells.InsertNextCell(triangle)
        # Read scalar field
            varname = list(f.available_variables.keys())[0]
            data = np.array(f.read(varname))  # shape: [npoints_2d, nplanes]
        # Transpose to [nplanes, npoints_2d] for easier looping
        data = data.T.flatten()
        # Build output polydata or unstructured grid
        output = vtk.vtkUnstructuredGrid()
        output.SetPoints(points)
        output.SetCells(vtk.VTK_TRIANGLE, cells)
        # Add scalar data
        vtk_array = ns.numpy_to_vtk(data, deep=True)
        vtk_array.SetName(varname)
        output.GetPointData().AddArray(vtk_array)
        output.GetPointData().SetActiveScalars(varname)
        outInfo.GetInformationObject(0).Set(vtk.vtkDataObject.DATA_OBJECT(), output)
        return 1
Doesn’t Fides support XGC data?
Hmm. That’s pretty interesting - I’ll have to read up on that. I did some google searching and didn’t see that come across my searches.
Let me play with it a bit. Thanks for the tip!
Checking here:
Interactive Post-hoc Visualization
Start ParaView. There are two ways to open files with the Fides reader. Either opening a JSON file that contains a Fides data model, or opening a BP file that contains attributes used for generating the data model.
My BPs don’t have the required attribute(s) - I assume just the JSON listed in your link. So, creating a JSON file containing exactly what is shown in your link, put in the root directory of the simulation where the BPs are located - including the timeseries data and the xgc.mesh.bp ‘file’, when I try to open it in PV, I get a message “A reader for .json could not be found. Please choose one.”
I don’t see Fides reader on the list (I’m playing with the “FDS Reader” - is this the same thing?) - my understanding was that it comes shipped with PV. Is that right? Do I need to do anything to enable it? Anything else I am missing?
Thanks for your help.
What version of ParaView are you using? I would suggest using 6.0.0 (release candidate available now). I believe that has Fides built into it. (I believe there was an issue preventing Fides from being in the Windows builds, but I think 6.0.0 has it.)
I’m using 6.0.0-RC2 MPI on Windows…
EDIT: I note that under Settings → IO, Fides reader isn’t listed, whereas on MacOS 6.0.0 RC2 it is.
Did you download the MPI version for Windows?
Yes, that’s the one I downloaded.
