Hi, I am building Paraview on Mac using this. When I run
cmake -GNinja -DPARAVIEW_USE_PYTHON=ON -DPARAVIEW_USE_QT=ON
-DPARAVIEW_USE_MPI=OFF -DVTK_SMP_IMPLEMENTATION_TYPE=TBB
-DCMAKE_BUILD_TYPE=Release …/paraview
I get these warnings:
CMake Warning at CMake/ParaViewClient.cmake:408 (add_executable):
Cannot generate a safe runtime search path for target paraview because
files in some directories may conflict with libraries in implicit
directories:
runtime library [libpqApplicationComponents-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkUtilitiesPythonInitializer-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libpqComponents-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libpqPython-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libpqCore-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libpqWidgets-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkqttesting-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkGUISupportQt-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkRemotingSettings-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkRemotingServerManager-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkjsoncpp-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkprotobuf-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkInteractionWidgets-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkRenderingContext2D-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkRenderingOpenGL2-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkRenderingHyperTreeGrid-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkRenderingUI-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkglew-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkIOImage-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkRemotingCore-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkPythonInterpreter-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkRemotingClientServerStream-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkPVVTKExtensionsCore-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkRenderingCore-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkImagingCore-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkFiltersSources-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkFiltersGeneral-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkfmt-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkParallelCore-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkIOXML-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkIOXMLParser-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkFiltersCore-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkCommonExecutionModel-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkWrappingPythonCore3.9-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkCommonDataModel-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkCommonTransforms-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkCommonMisc-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkCommonMath-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkkissfft-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkCommonCore-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtksys-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
