Build of Catalyst-v5.6.0-Base-Enable-Python fails
I am building Catalyst on Linux x86_64 with gcc 6.3.1. The build fails at the very end, while building pvserver, pvpython, pvbatch and pvdataserver. The error is ‘cannot find openpty’, see attachment. In case that it is relevant, I use a custom build of python-2.7.16, because the system python is 2.6.
Could you advise how to resolve this issue, please?
Thanks,
Ted
Scanning dependencies of target vtkPVPythonCatalystPython
[100%] Building CXX object CMakeFiles/vtkPVPythonCatalystPython.dir/vtkPVPythonCatalystPythonInit.cxx.o
[100%] Linking CXX static library lib/libvtkPVPythonCatalystPython-pv5.6.a
[100%] Built target vtkPVPythonCatalystPython
/ascldap/users/tesari/local/python-2.7.16/lib/libpython2.7.a(posixmodule.o): In function posix_tmpnam': /ascldap/users/tesari/projects/Python-2.7.16/./Modules/posixmodule.c:7648: warning: the use oftmpnam_r’ is dangerous, better use mkstemp' /ascldap/users/tesari/local/python-2.7.16/lib/libpython2.7.a(posixmodule.o): In functionposix_tempnam’:
/ascldap/users/tesari/projects/Python-2.7.16/./Modules/posixmodule.c:7595: warning: the use of tempnam' is dangerous, better usemkstemp’
/ascldap/users/tesari/local/python-2.7.16/lib/libpython2.7.a(posixmodule.o): In function posix_forkpty': /ascldap/users/tesari/projects/Python-2.7.16/./Modules/posixmodule.c:4022: undefined reference toforkpty’
/ascldap/users/tesari/local/python-2.7.16/lib/libpython2.7.a(posixmodule.o): In function posix_openpty': /ascldap/users/tesari/projects/Python-2.7.16/./Modules/posixmodule.c:3962: undefined reference toopenpty’
collect2: error: ld returned 1 exit status
CommandLineExecutables/CMakeFiles/pvdataserver.dir/build.make:155: recipe for target ‘bin/pvdataserver’ failed
make[2]: *** [bin/pvdataserver] Error 1
CMakeFiles/Makefile2:8092: recipe for target ‘CommandLineExecutables/CMakeFiles/pvdataserver.dir/all’ failed
make[1]: *** [CommandLineExecutables/CMakeFiles/pvdataserver.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs…
[100%] Built target pvtkpython
[100%] Built target vtkpython
CommandLineExecutables/CMakeFiles/pvserver.dir/build.make:155: recipe for target ‘bin/pvserver’ failed
make[2]: *** [bin/pvserver] Error 1
CMakeFiles/Makefile2:8399: recipe for target ‘CommandLineExecutables/CMakeFiles/pvserver.dir/all’ failed
make[1]: *** [CommandLineExecutables/CMakeFiles/pvserver.dir/all] Error 2
CommandLineExecutables/CMakeFiles/pvbatch.dir/build.make:155: recipe for target ‘bin/pvbatch’ failed
make[2]: *** [bin/pvbatch] Error 1
CMakeFiles/Makefile2:8539: recipe for target ‘CommandLineExecutables/CMakeFiles/pvbatch.dir/all’ failed
make[1]: *** [CommandLineExecutables/CMakeFiles/pvbatch.dir/all] Error 2
CommandLineExecutables/CMakeFiles/pvrenderserver.dir/build.make:155: recipe for target ‘bin/pvrenderserver’ failed
make[2]: *** [bin/pvrenderserver] Error 1
CMakeFiles/Makefile2:8297: recipe for target ‘CommandLineExecutables/CMakeFiles/pvrenderserver.dir/all’ failed
make[1]: *** [CommandLineExecutables/CMakeFiles/pvrenderserver.dir/all] Error 2
CommandLineExecutables/CMakeFiles/pvpython.dir/build.make:155: recipe for target ‘bin/pvpython’ failed
make[2]: *** [bin/pvpython] Error 1
CMakeFiles/Makefile2:8195: recipe for target ‘CommandLineExecutables/CMakeFiles/pvpython.dir/all’ failed
make[1]: *** [CommandLineExecutables/CMakeFiles/pvpython.dir/all] Error 2
Makefile:129: recipe for target ‘all’ failed
make: *** [all] Error 2
I figured it out. Linking with -lutil fixed the issue.
Thanks,
Ted
