I am trying to build Paraview 5.6.1 in my Linux-OS (Archlinux) with Openturns, but I have this error:
CMake Error at VTK/Filters/OpenTurns/CMakeLists.txt:1 (find_package):
By not providing "FindOpenTURNS.cmake" in CMAKE_MODULE_PATH this project
has asked CMake to find a package configuration file provided by
"OpenTURNS", but CMake did not find one.
Could not find a package configuration file provided by "OpenTURNS"
(requested version 1.8) with any of the following names:
OpenTURNSConfig.cmake
openturns-config.cmake
Add the installation prefix of "OpenTURNS" to CMAKE_PREFIX_PATH or set
"OpenTURNS_DIR" to a directory containing one of the above files. If
"OpenTURNS" provides a separate development package or SDK, be sure it has
been installed.
Did I miss something? cause the installation process mentions that I only have to turn on the Cmake option PARAVIEW_USE_OPENTURNS. btw, without Openturns, Paraview is built with no errors.
I installed OpenTURNS1.8, it is installed in /home/xxxx/.local/share/openturns and there is no cmake file called OpenTURNSConfig.cmak. it contains three folders /doc ‘/examples’ and ‘/validation’.
The [version] argument requests a version with which the package found should be compatible (format is major[.minor[.patch[.tweak]]] ). The EXACT option requests that the version be matched exactly.
