Build problem: 'vtkm::tbb-NOTFOUND'
Hello!
I’m trying to build ParaView on Ubuntu 20.04 LTS. I’ve followed the instructions on ParaView/build.md at master · Kitware/ParaView · GitHub
After sucessfully (?) setting things up with cmake, I get an error when i try to ninja-build. The error is:
ninja: error: ‘vtkm::tbb-NOTFOUND’, needed by ‘lib/libvtkm_cont-pv5.9.so.1’, missing and no known rule to make it
More details below. I would really appreciate some help. I have been looking around for a solution for quite some time now, but I am at a loss for how to solve this.
gfield@gfield-desktop:/usr/local/src/paraview-build$ sudo cmake -GNinja -DPARAVIEW_USE_PYTHON=ON -DPARAVIEW_USE_MPI=ON -DVTK_SMP_IMPLEMENTATION_TYPE=TBB -DCMAKE_BUILD_TYPE=Release ../paraview-source
-- Using 'QtHelp' without 'QtWebEngine' will ignore embedded javascript and *.js files for documentation
-- Found Python3: /usr/bin/python3.8 (found suitable version "3.8.5", minimum required is "3.2") found components: Interpreter Development.Module Development.Embed
CMake Warning at VTK/Rendering/OpenGL2/CMakeLists.txt:359 (message):
  X11::Xcursor not found; custom cursors will be ignored.
-- Bitwidth Mapping: preferring `long` over `long long` for c++11 compatibility
-- Bitwidth Mapping Results:
--  conduit::int8  native type: signed char
--  conduit::int16 native type: signed short
--  conduit::int32 native type: signed int
--  conduit::int64 native type: signed long
--  conduit::uint8  native type: unsigned char
--  conduit::uint16 native type: unsigned short
--  conduit::uint32 native type: unsigned int
--  conduit::uint64 native type: unsigned long
--  conduit::float32 native type: float
--  conduit::float64 native type: double
-- Found Python3: /usr/include/python3.8 (found version "3.8") found components: Development Development.Module Development.Embed
-- Enabled modules: VTK(159), ParaView(50 + 12)
-- Configuring done
-- Generating done
-- Build files have been written to: /usr/local/src/paraview-build
gfield@gfield-desktop:/usr/local/src/paraview-build$ sudo ninja
ninja: error: 'vtkm::tbb-NOTFOUND', needed by 'lib/libvtkm_cont-pv5.9.so.1', missing and no known rule to make it
It would appear as though VTK-m did not find TBB. It should error in that case instead of making this occur. I have an issue to improve VTK-m’s third party handling.
Cc: @vbolea @sujin
Do you have any idea of how to fix this issue?
Before building, I installed all of the prerequisite packages listed in ParaView/build.md
sudo apt-get install git cmake build-essential libgl1-mesa-dev libxt-dev qt5-default libqt5x11extras5-dev libqt5help5 qttools5-dev qtxmlpatterns5-dev-tools libqt5svg5-dev python3-dev python3-numpy libopenmpi-dev libtbb-dev ninja-build
When I list installed packages related to vtk and tbb I find
gfield@gfield-desktop:/usr/local/src/OpenFOAM-v2012$ apt list --installed *vtk*
Listing... Done
libvtk6.3/focal,now 6.3.0+dfsg2-5build2 amd64 [installed,automatic]
libvtk7-dev/focal,now 7.1.1+dfsg2-2ubuntu1 amd64 [installed]
libvtk7-java/focal,now 7.1.1+dfsg2-2ubuntu1 amd64 [installed,automatic]
libvtk7-jni/focal,now 7.1.1+dfsg2-2ubuntu1 amd64 [installed,automatic]
libvtk7.1p-qt/focal,now 7.1.1+dfsg2-2ubuntu1 amd64 [installed,automatic]
libvtk7.1p/focal,now 7.1.1+dfsg2-2ubuntu1 amd64 [installed,automatic]
python3-vtk7/focal,now 7.1.1+dfsg2-2ubuntu1 amd64 [installed,automatic]
tcl-vtk7/focal,now 7.1.1+dfsg2-2ubuntu1 amd64 [installed,automatic]
and
gfield@gfield-desktop:/usr/local/src/OpenFOAM-v2012$ apt list --installed *tbb*
Listing... Done
libtbb-dev/focal,now 2020.1-2 amd64 [installed]
libtbb2/focal,now 2020.1-2 amd64 [installed,automatic]
Do I need to install/build VTK-m before building ParaView? How come that is not listed as a dependency?
VTK-m is in ParaView because it is in VTK itself (vendored and such). I don’t know why VTK-m isn’t finding TBB out of the box. Some --debug-find output around VTK-m’s FindTBB searchings could help.
Hmm. I ran
sudo ninja -d explain
A snapshot of the output is
ninja explain: deps for 'CMakeFiles/vtkPVAdaptorsPagosaPython.dir/CMakeFiles/vtkPV
AdaptorsPagosaPython/vtkPVAdaptorsPagosaModulePython.cxx.o' are missing
ninja explain: deps for 'VTK/Wrapping/Tools/CMakeFiles/WrapPython.dir/vtkWrapPython.c.o' are missing
ninja explain: VTK/Wrapping/Tools/CMakeFiles/WrapPython.dir/vtkWrapPython.c.o is dirty
ninja explain: deps for 'VTK/Wrapping/Tools/CMakeFiles/WrapPython.dir/vtkWrapPythonClass.c.o' are missing
ninja explain: VTK/Wrapping/Tools/CMakeFiles/WrapPython.dir/vtkWrapPythonClass.c.o is dirty
ninja explain: deps for 'VTK/Wrapping/Tools/CMakeFiles/WrapPython.dir/vtkWrapPythonConstant.c.o' are missing
ninja explain: VTK/Wrapping/Tools/CMakeFiles/WrapPython.dir/vtkWrapPythonConstant.c.o is dirty
ninja explain: deps for 'VTK/Wrapping/Tools/CMakeFiles/WrapPython.dir/vtkWrapPythonEnum.c.o' are missing
ninja explain: VTK/Wrapping/Tools/CMakeFiles/WrapPython.dir/vtkWrapPythonEnum.c.o is dirty
ninja explain: deps for 'VTK/Wrapping/Tools/CMakeFiles/WrapPython.dir/vtkWrapPythonMethod.c.o' are missing
ninja explain: VTK/Wrapping/Tools/CMakeFiles/WrapPython.dir/vtkWrapPythonMethod.c.o is dirty
The corresponding directories can be found in my build-directory, but they seem to be empty. I have tried building in my source-directory as well, but that does not work. I get the following error message:
CMake Error at CMakeLists.txt:36 (message):
  ParaView requires an out-of-source build.  Please create a separate binary
  directory and run CMake there.
(I have one directory called paraview-source/, and one called paraview-build/, both located at /usr/local/src/.)
Could something have gone awry in the first step (i.e. setting up makefiles with cmake)? I’m still at a loss of what to do.
  1. Why are you running as sudo? You really shouldn’t build as sudo (install can make sense). (Later info shows you’re building in /usr/local…why not build in your $HOME?)
  2. It seems that you once configured ParaView from its source directory. Remove CMakeCache.txt and CMakeFiles from the source tree and try again.
  3. Finding TBB has nothing to do with ninja -d explain. You can run cmake --debug-find $other_configure_args to get that information.
FYI, I’m seeing the same problem with Ubuntu 20.04. It happens with 655528fc9b64cd3a59eb00212c8b18afebda8264 (3/11), but not with 1e857afe005c24c79fb2146180005ae7e992e929 (3/5).
The difference is that in VTK, we now try to use TBBConfig.cmake if possible. Could someone please get a backtrace as to how TBB is being found within VTK-m with this change? Using --debug-find and snipping to around VTK-m’s find_package(TBB) would be ideal.
Hello! I haven’t had time to work on this for a couple of days, but here comes a few answers.
I have gotten the impression that it is a good habit to keep local software (intended for any user) in /usr/local. I’m no expert Linux user though, so I could be wrong. :slight_smile:
I tried building in the source directory (didn’t work), when the out-of-source build didn’t work. I have now removed the mentioned files and directories from the source directory.
I have ran cmake --debug-output (couldn’t find --debug-find). There’s over 10,000 output lines, but only 30 of them contain “tbb”. Below I printed a snapshot. (The others are more or less identical, but with other sub-directories of /usr/local/src/paraview-build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/). I can’t find any relevant errors/warnings.
   Entering             /usr/local/src/paraview-source/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/exec/tbb
   Called from: [1]	/usr/local/src/paraview-source/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/exec/CMakeLists.txt
   Entering             /usr/local/src/paraview-source/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/exec/tbb/internal
   Called from: [1]	/usr/local/src/paraview-source/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/exec/tbb/CMakeLists.txt
   Entering             /usr/local/src/paraview-source/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/exec/tbb/internal/testing
   Called from: [1]	/usr/local/src/paraview-source/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/exec/tbb/internal/CMakeLists.txt
   Returning to         /usr/local/src/paraview-source/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/exec/tbb/internal
-- Generating /usr/local/src/paraview-build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/tbb
   Called from: [1]	/usr/local/src/paraview-source/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/tbb/CMakeLists.txt
-- Generating /usr/local/src/paraview-build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/tbb/internal
   Called from: [1]	/usr/local/src/paraview-source/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/tbb/internal/CMakeLists.txt
-- Generating /usr/local/src/paraview-build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/tbb/testing
   Called from: [1]	/usr/local/src/paraview-source/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/tbb/testing/CMakeLists.txt
sudo is usually left for the install step. Building can happen anywhere and should not be done with root permissions.
Ah, that’s a newer CMake feature then. It was added in CMake 3.17. You can download a newer version from CMake’s release page; there’s no need to install it globally because you can just extract the Linux tarball and use it from wherever that is.
I stumbled onto this today. Let me know if you want steps to reproduce @ben.boeckel
I’m looking for --debug-find output around VTK-m’s TBB searching to know why it fails.
Not sure what you mean, I’ve opened an issue:
https://gitlab.kitware.com/paraview/paraview/-/issues/20557
