I assume there is where I “configure paraview-superfield accordingly to your need” and “ENABLE_qt5 and USE_SYSTEM_qt should be ON”, but I don’t know what that means.
Yes, you have to choose a generator and click Finish. Then click the ‘Configure’ button and the options will appear. You may want to read a little about how cmake-gui works.
Great! Thanks for the answer.
I used Ninja as the generator in cmake-gui (don’t know if that’s correct because the post mentioned ninja after cmake-gui)
I changed CMAKE_BUILD_TYPE from Debug to Release and CMAKE_INSTALL_PREFIX from C:\Program Files (x86)\paraview-superbuild to C:/pv/pvsb. I don’t know if that’s correct but made more sense to me.
The system is: Windows - 10.0.18362 - AMD64
Compiling the C compiler identification source file "CMakeCCompilerId.c" succeeded.
Compiler: C:/Program Files (x86)/Microsoft Visual Studio/2019/Community/VC/Tools/MSVC/14.23.28105/bin/Hostx86/x86/cl.exe
Build flags:
Id flags:
The output was:
0
Microsoft (R) C/C++ Optimizing Compiler Version 19.23.28107 for x86
Copyright (C) Microsoft Corporation. All rights reserved.
CMakeCCompilerId.c
Microsoft (R) Incremental Linker Version 14.23.28107.0
/out:CMakeCCompilerId.exe
CMakeCCompilerId.obj
Compilation of the C compiler identification source "CMakeCCompilerId.c" produced "CMakeCCompilerId.exe"
Compilation of the C compiler identification source "CMakeCCompilerId.c" produced "CMakeCCompilerId.obj"
The C compiler identification is MSVC, found in "C:/pv/pvsb_b/CMakeFiles/3.16.0-rc4/CompilerIdC/CMakeCCompilerId.exe"
Compiling the CXX compiler identification source file "CMakeCXXCompilerId.cpp" succeeded.
Build flags:
Id flags:
The output was:
0
/out:CMakeCXXCompilerId.exe
CMakeCXXCompilerId.obj
Compilation of the CXX compiler identification source "CMakeCXXCompilerId.cpp" produced "CMakeCXXCompilerId.exe"
Compilation of the CXX compiler identification source "CMakeCXXCompilerId.cpp" produced "CMakeCXXCompilerId.obj"
The CXX compiler identification is MSVC, found in "C:/pv/pvsb_b/CMakeFiles/3.16.0-rc4/CompilerIdCXX/CMakeCXXCompilerId.exe"
Determining if the C compiler works passed with the following output:
Change Dir: C:/pv/pvsb_b/CMakeFiles/CMakeTmp
Run Build Command(s):C:/Ninja/ninja.exe cmTC_174ab && [1/2] Building C object CMakeFiles\cmTC_174ab.dir\testCCompiler.c.obj
[2/2] Linking C executable cmTC_174ab.exe
Detecting C compiler ABI info compiled with the following output:
Run Build Command(s):C:/Ninja/ninja.exe cmTC_c5c01 && [1/2] Building C object CMakeFiles\cmTC_c5c01.dir\CMakeCCompilerABI.c.obj
[2/2] Linking C executable cmTC_c5c01.exe
Determining if the CXX compiler works passed with the following output:
Run Build Command(s):C:/Ninja/ninja.exe cmTC_c82f5 && [1/2] Building CXX object CMakeFiles\cmTC_c82f5.dir\testCXXCompiler.cxx.obj
[2/2] Linking CXX executable cmTC_c82f5.exe
Detecting CXX compiler ABI info compiled with the following output:
Run Build Command(s):C:/Ninja/ninja.exe cmTC_9d1ec && [1/2] Building CXX object CMakeFiles\cmTC_9d1ec.dir\CMakeCXXCompilerABI.cpp.obj
[2/2] Linking CXX executable cmTC_9d1ec.exe
Determining size of void* passed with the following output:
Run Build Command(s):C:/Ninja/ninja.exe cmTC_a39b0 && [1/2] Building C object CMakeFiles\cmTC_a39b0.dir\void_ptr_size.c.obj
[2/2] Linking C executable cmTC_a39b0.exe
I installed the last version of Python (3.8), but still got this error message.
