Buildslave feature idea : Test regexp
It would be nice to have a feature to select which run to test instead of running all test.
Something to pass to ctest -R would be enough.
I know that one can edit the CMakeLists.txt to disable all the test except a few, but it is not practical.
This has been discussed on our side a bit in the past, but obviously never implemented on the buildbots. @utkarsh.ayachit @ben.boeckel is this potentially feasible with gitlab CI?
should be doable in gitlab-ci via variables
You can add a WIP commit which modifies the ctest_test.cmake script to pass extra arguments to ctest_test() to limit your testing.
How else could we pass variables to an MR build that doesn’t require a diff to the MR (that needs ripped off at some point which will rerun full CI anyways)?
Adding a WIP commit is doable but not practical. tbh, I end up running all the tests and stalling other people work just to avoid pushing a WIP commit.
Can’t arguments be passed from buildslave to the ctest call ?
@ben.boeckel : I couldn’t find this file, could you give some details on how to do this ?
With gitlab-ci, our pattern is to use a CTest script that you can edit in your MR to restrict the test suite (please do it with a WIP commit so it doesn’t affect master).
I’m still confused on how one is supposed to do that.
Could you open a mr just to show this ?
You can edit the .gitlab/ci/ctest_test.cmake to have:
ctest_test(
  PARALLEL_LEVEL "${nproc}"
  RETURN_VALUE test_result
  INCLUDE "SomeTestRegEx" # WIP: For faster turnaround.
  EXCLUDE "${test_exclusions}")
I’ve been trying without success here : https://gitlab.kitware.com/paraview/paraview/-/merge_requests/4273/diffs#note_802016
After a discussion with @ben.boeckel on the linked MR, this is currently not possible in any practical way.
That would be a very nice to have, especially for WIP MR that just want to check their tests are passing before running the whole test suite.
With gitlab-ci being adopted now, it would be great to add this as well :slight_smile:
Another related feature request: it would be nice to be able to run the buildbots without running tests, only to see if there are build errors/warnings.
I’m not really keen on adding features to buildbot. Hopefully it isn’t used (much) in a few months at all.
You can add INCLUDE_REGEX to ctest_test.cmake in a WIP commit to your MR to restrict the set of tests. But it really should run all of them eventually to make sure you’re not breaking things.
@nicolas.vuaille meant to be able to only build and not run the tests with the ParaView ci, being buildbot or gitlab.
Great, I will try it soon.
clang-tidy will essentially do that once it’s on gitlab-ci. It will be Linux only (we don’t have enough macOS and Windows capacity to have a dedicated build-only and running the tests is, by far, the more common case, so that will remain the default).
