C++ VTK application and pvserver
Hello Everyone,
is it possibile to connect an c++ vtk/qt application with pvserver in order to obtain a remote rendering?
Thanks
the obvious answer would be to use ParaView itself to connect ot a pvserver. If not, the easiest way is to create a ParaView-based applications.
You may look at the examples: https://gitlab.kitware.com/paraview/paraview/-/tree/master/Examples/CustomApplications
Best
Hi Francois, thanks.
I have already developed a VTK application. So, I would like to connect to a remote server for rendering minimizing changes.
Fabio,
You could connect both applications by importing into your app all the ParaView machinery but there will be absolutely no link between the VTK pipelines you may create and the ParaView ones. And thus, you won’t be able to delegate the rendering to the server.
Cheers
Thanks for the clarification
